Improving a Marx Windup Motor
Marx windup motors have a lot going for them; they are durable, perform well, plentiful and affordable. However, like any mechanism with an age that is measured in decades, they can develop problems. Over the years I have learned how to deal with the normal Marx issues such as loose wheels, broken mainsprings, malfunctioning governors and slipping ratchets. But, the die-cast mainspring hub will occasionally break, and the only fix I had for that was to find a donor motor with a good mainspring hub. I decided that I wanted to be able to make my own hub in case I couldn’t find a replacement, and while I was at it, I wanted to develop a more durable ratchet, too.
The mainspring hub itself wasn’t an issue except for the square hole for the key. The new hub was machined out of 360 brass, and a 1/8" hole was drilled through it for the keyhole. I made broaches to cut the square keyhole out of the original 1/8" round hole.
Here is a picture of the new brass mainspring hub on the left and an original Marx mainspring hub on the right:
The orginal Marx ratchet uses a plate with pawls stamped into it that engage matching holes in the big gear. Over time, the pawls and the mating edge of theholes get worn out, resulting in a malfunctioning ratchet. It can be repaired, but just for fun I wanted to try my hand a making a more durable ratchet. I soldered a new drum for a ball & ramp style of one-way clutch to an original Marx big gear, then machined a center ramp that pressed onto
Brilliant! You may just have the makings of a little side business here.
Thank you! I like to work on clockwork motors, but I wouldn’t want to do it for a living… ha!
If anyone from Kalmbach should see this, I don’t know why my initial text is fine, but subsequent text after the images has the red underlining. The underlined text was red when I first posted, even though I did not do anything to the color or format of it when I typed it. I was able to select a black color for it, but cannot seem to get rid of the red underlining. Hmmmm…
Thank you,
James
If you wanted to make these parts commercially, I would recommend you get them made by a CNC machine shop and wholesale them through the parts guys. There is probably a good market for these pieces. This approach keeps you from doing any realy work. Just ship the parts and put the check in the bank.
Brilliant…
