Installing a Keep Alive on a BLI
Hi Everyone,
Does anyone have any suggestions for installing a TCS Keep Alive on a BLI EMD NW2 switcher. It’s a nice DCC switcher but doesn’t do well on crossovers where I run it in my staging yard. Is replacing the board with another board witha KA built in a viable option? BLI doesn’t want to share any information which rules it our for me with any further purchases. I recently installed my first TCS Wow surround kit in a Atlas Trainman that I got when I first started in HO a few years ago, and it is amazing in how it runs, sound, options, etc.
Jim
I’d love to help you on this one Jim, but I’m in the same boat: i need to gut a BLI steamer and stick a TCS Wow w/ keep-alive in it. Gorgeous engine but picky as heck on the turnouts.
Randy? Tom? Help?
Stu
I just…just finished (literarlly 15 min. ago) installing a TCS decoder in a Proto 2000 0-8-0 switcher, which was a relatively simple plug 'n play installation. All it required was to disconnect the NMRA 8-pin socket from the DC board in the tender, unscrew and replace the DC board with a TCS LL8-LED decoder, and plug the 8-pin socket onto the new TCS decoder.
Along with that I installed a TCS KA1 keep-alive module because this was one of the 1st-release Proto 2000 0-8-0 switchers which, IIRC, didn’t come with all-wheel pickup until the 2nd release. I also replaced the incandescent front & rear headlights with LEDs.
I tested everything on my programming track and the decoder, keep-alive module, and LEDs all work as expected - Woohoo! In fact, I just timed the switcher on speed step 001 and it crawls at…0.14 sMPH. [:O] Not too shabby motor-control; hence why TCS is my go-to default decoder for DCC installations.
Jim,
Is there a sound decoder in your NW2 presently? Or, is it just a motor-only decoder?
If the latter then I suspect that decoders with KA-capacity will be larger and possibly not fit under the hood. Even if you were able to add a KA1 to your present decoder and place it in your cab area, it might be a rather tight fit.
Thanks to the Loksound manual, I was able to install a homemade KA module in my older Walthers SW1 Stewart VO-660. The cap alone was at least 1" OD and its base just barely fit inside the cab, as seen below:
Apart from cramming it all in (the switcher isn’t all that big), electrically it’s a no-brainer. The wires all plug in to various parts of the BLI board, so just unplug them, and likely yoiu will need to cut the connectors off, but it will be obvious where the wires go (track pickups, motor, headlight, etc) so it should be no problem to reattach them to the approriate points on a WOWSound decoder. Unless they have a smaller motherboard, you probably can’t go that route, but rather will need to use a hard wired WOW decoder. The same speaker should be fine.
If you google some of the DIY kepp alive connections, you will see how to find the proper connection point on nearly any decoder. BLI or whatever, the FIRST thing the track pickup wires connect to in the circuit is the bridge rectifier where you need to get the negative side for the keep alive capacitor from. Outside of the main chip, the main rectifier diodes are probably some of the biggest components on the board. A single bridge will be rather square with 4 leads, but most decoders seem to use individual diodes - in which case there will be 4 identical components all right next to one another as a clue. BLI won’t tell you where this is - soldering wires to the decoder will void the warranty. None of the others gave up this information either - new models provide the keep alive connections so those are documented but no one tells you where to solder wires on for keep alive for any of their products that don’t have said connector already on the decoder. The info on how to attach keep alives to various decoders all came from the investigation of people like Marcus with his page on keep alives.
I’m glad that wasn’t the case with the TCS decoder, Randy. I guess since it was their decoder and their KA1 module, there was nothing proprietary to hide. In fact, it couldn’t have been a much simpler installation for connecting the KA1 to the LL8-LED decoder than it was. The KA1 manual clearly outlined where the module wires connected to a decoder - i.e. ground and 12V(+). And the LL8 manual outlined where those specific pads were located.
Hi Tom,
Yes, there is already a sound decoder on the switcher.
Jim,
According to TCS the KA1 module is 0.647" x 1.052" x 0.293"(H). Try measuring the cab of your NW2 to see if that might fit inside. And it’s only two wires to hook the module to another decoder. With ~6" of wire, that should be plenty of length to accomplish that. Just be sure you are soldering them to the correct pads of your Paragon/Paragon2 decoder.
Hey Tom, that looks like a VO660, not an SW1 [:D]
I guess the WOW decoders aren’t as big as they look. Seems smaller than a Tsunami but bigger than a Select Micro.
Doh! - You’re right, Randy. Someone’s asleep at the helm. [D)] Earlier post modified with correct info. Thanks for keeping me honest. [:D]
Have to, since I have the same one, only in a MUCH snazzier olive green paint scheme [:D] I need some more, although it may look like my railroad only bought Baldwin switchers and Alco road switchers if I keep this up.
Could be worse scenarios, Randy…could be worse. [:D]
This is response to the first question on this topic – could a current-keeper be installed in a Broadway Limited Imports (BLI) Paragon-2 EMD-SW1500 switcher to help avoid engine stalling when going over switches and crossovers. I have a BLI Paragon-2 EMD-NW2 switcher and this was a question I also had. I believe the inter-workings of these two engines are the same. From the comments related to this topic, the general consensus was a lack of space for a current keeper. To address that question, I removed the shell of the engine. To do this, first remove the 2 back handrails that go between the shell and the frame. Then looking at the bottom of the engine you should observe 2 front and 2 back tabs. Gently squeeze the shell at either the front or rear tabs and slowly pull up on the shell. Once the shell slightly releases, do the same for the other tabs.
Once inside, I observed there is a fair amount of space above the decoder at the back. Taking a few measurements, it appeared that a TCS KA1 Keep Alive (1.063" x 0.35" x 0.244") might fit and it does. The next issue was locating where to solder the wires. The information of an excellent site on current-keepers (http://www.members.optusnet.com.au/mainnorth/alive.htm) indicates that I needed to find DC-positive and DC-negative connection points. For this decoder with plug-in connections for everything, it was going to require taking DC voltage measurements using a multi-meter at the bridge-rectifier diodes. These are the square chips located near the large capacitor. With the engine on the a powered and circuit protected track, I was looking for a two solder points on the diodes that would supply +12 DC-Volts. Do not use to the + terminal of the large capacitor as a test point as this only supplies power to the sound system and not to the motor. However, the other terminal of the large capacitor can be used for the DC-negative as it s
