International vs. domestic containers
I frequently see references to international and domestic containers. Are these two types of containers physically different from each other? Or, are the writers of articles just referring to how the containers are being deployed, not physical differences?
It sure seems like it would be simpler if they were both the same.
I know their lengths are different. International containers are 40’ or 20’ long. Domestic containers are 53’ long.
The only differences are gross weight and dimensions.
Domestic containers are:
53’ x 8’2" x 9’6" with a maximum GWR of 67,200 lbs.
ISO Containers are:
20’ x 8’ x 8’6" Dry/Flatrack/Tanktainer
40’ x 8’ x 8’6" also come in High Cube 9’6" Dry/Flatrack/Refrigerated
45’ x 8’ x 8’6" also come in High Cube 9’6" Dry/Refrigerated
Most ISO containers have a maximum GWR of 67,055 lbs.
IIRC, the first domestic containers weren’t stackable because they weren’t build to the same standard. They could only be “topload”. That doesn’t seem to be the case anymore.
What the two versions have in common is using the same dimensions and methods for interlocking the containers. The dimensions are based on the 20’ and 40’ containers. There also have been, and may still be around, 28’ containers for domestic use. Those are supplied with the standard locking connections as the 20’, with an overhang off the front (the 45’s and 53’s have symmetrical overhang front and back).
Note that it is common to see a 53’ domestic container stacked on top of an international on double-stack cars.
There is nothing precluding an international container being used in domestic service, except that it can bulk out too soon. In fact, once international containers are removed from the ship, they ARE essentially domestic containers.
Going the other direction is near impossible. Container ships cannot accept our domestic containers below decks. And stacking them on top is very limited and a PITA.
This tends to be true for the international 45’s, but less of a problem as the container width stays the same. 45’ containers cannot be stowed below deck.
I believe also that most/some domestic containers can’t be stacked more than two-high. That is also limiting on a ship.
There also have been 48’ domestic containers, preceding the 53’s. There might still be some around.
Ed
I don’t remember the last time I actually saw a 28 footer.
28’ containers have long been out of service… Roughly 26 years now… A failed experiment involving; BN, ATSF, and UPS. BN America, and UPS were the only operators of 28’ containers. However the 56’ well cars created for those containers are still in service.
20 ft containers - Trains Magazine - Trains News Wire, Railroad News, Railroad Industry News, Web Cams, and Forms
28-foot Domestic Container Photo Gallery
Here’s a link to a photo of a 28’ container in service in 2011:
http://www.rrpicturearchives.net/showPicture.aspx?id=2596965
NOT as a container, as such. But still, in use.
I think there were only 100 of the 56’ well cars built. They do show up; I’ve taken pictures of a couple.
Ed
I would guess that the 28’ container was an attempt at a variant with increased flexibility of the trailer usually found in double bottoms.
Were any container chassis constructed that would facilitate the hauling of double 28 footers?
I have never seen any container chassis that could be doubled over the road.
Here in Michigan we do. It’s not common but every now and then you can see double 20’s.
Haven’t seen any leaving or going to the Port of Baltimore.
Is this part of the conversation about two 20’ containers on two chassis towed by one truck? Or is it about two 20’ containers on a single chassis?
Ed
2 20ft containers, each on its own trailer.
Really sketchy is the loading of two 20 foot containers loaded on a single flatbed trailer and secured by ratchet straps.
Yeah you won’t see it outside of Michigan. We have a 164K GCVWR on a Tractor Trailer Combo. Double 20’s here mostly head to the thumb region for loading grains.
Straps being a key point.
Saw a container moving on a truck the other day with what appeared to be just one such strap… Undoubtedly privately owned for storage and being moved between points, as opposed to carrying cargo.
I’m convinced that any containers held down by straps are NOT in intermodal service. I cannot imagine someone at a port dropping a container down onto a chassis that didn’t have box connectors at the four corners.
Ed
I have no idea of the ownership or where they were loaded - just seen them moving on I-70 West of Baltimore.
The lack of long combination vehicle (LCV) container hauls, is in part, a function of a disjointed regulatory environment in the U.S. Congress locked in federal and state length and weight laws in 1991, but the technology has marched on.
Here is a “B train” (trailers linked by a fifth wheel) 4x20’ lash up:
https://youtu.be/VwonK7Kx5Ls
And the same with a 2x40’ hookup.
https://youtu.be/XG05RfVZhZc
Here’s a B triple up in Canada:
https://youtu.be/q-YIblzUZJY
“A trains” are the pintle hooked trailers like those used on UPS pup trailers.
