Is it normal to do bad track work at first?
Does the sun shine? LOL
I am on my third layout, and the learning curve is, indeed, great.
When I constructed my first layout, I naively thought that I could just nail down track on plywood and all would be just fine. Major mistake. I nearly quit the hobby due to derailments.
I took my time, so to speak, on my second layout, but derailments were still a problem because I was inexperienced and did not research the subject of track laying sufficiently.
On my third and current layout, I still struggle somewhat with shoddy track work. On this layout, I used Woodland Scenics Foam Track Bed and nailed down flex track. The problems were everywhere. Someday, I will do a fourth layout, and perfect track work will be my number one objective.
Good track laying starts with good benchwork. My bench work is 1/2" plywood screwed on top of 2x4 frame work. If the surface is uneven, bows or cups, or anything short of even and level, trouble lies ahead.
My second problem is my continued determine to nail down the track. When you do this, you clearly risk dips and humps. No, you don’t risk dips and humps, you create dips and humps because it is nearly impossible to nail each and every nail to the proper depth. Besides the fact that nails are not prototypical, they don’t look good. My fear with using caulk is that there is no second chance. You have to get alignment perfect on the first attempt before the caulk dries.
If you have even and level bench work and you decide to carefuly caulk the track work, there are several issues to be overcome. The track must be absolutely straight. Use a pair of carpenter’s levels, one on each side of the track. Align the rails vertically to eliminate any unevenness between the connecting rails. Avoid dips and humps at all cost. Solder two pieces of flex track together to fo
