Here’s how I would do it…
Break it up into 3 supplies.
1 DCC specifically to supply the track (~14.0VDCC HO)
1 for accessories (12V + 5V + Ground Lines)
1 for LED lighting
Now how much lighting do you need? Well figure out how many 60 watt bulbs it would take to light your layout. Grab 3 of 4 INCADECENT bulbs above your layout, and line them up Adjust the space between them till you reach adequate brightness. You can figure out how many lights per foot you need.
Now a 60 Watt bulb puts out about 700 lumens. So now you can figure out how many lumens per foot you need. This will help you figure out if you need to double up on your LEDs (Some aren’t as bright as others…so read the specs on lumens per meter or lumens per foot)
Next you know how big your layout is, and you can calculate the number of 60 watt bulbs your layout needs based on the bulbs per foot. (Draw it on graph paper if you have to)
A LED bulb is roughly 6’x more efficient then a traditional bulb. So 10 Watts will produce the same Lumen output as a 60 Watt bulb (same brightness) But you have to go through a power supply which is 80% efficient on average.
So lets say you calculate you need about 12 regular bulbs. That’s 12*700 lumens/bulb = 8400 lumens total. This should help you figure out how much LED strip you will need to buy. (They rate them by lumen output)
12*60 Watts = 720 incandecent Watts total
720 / 6 = 120 Watts for LED equivalent.
Would I buy a 120 Watt supply? NO! That’s running it at full tilt and that will wear it out early. I would run a supply at no more than 80% of what it’s rated at. So…
120 / .8 = 150.0 Watts supply output total.
So I would find the closest power supply that is at least 150 watts output.
150 / .8 (for 80% power conversion efficiency) = 187.5 Watts pulled f
