Is there any help for tango trucks (cheap push in trucks)
OK, I know they are junk but is there away to make them a little better? I am cutting the coupler boxes off and using Kadee boxes and # 5’s as I can. I have all so tuned the trucks and installing either PK 2000 or Atlas metal axels.
Some of the trucks fit lose and need’s some help to fit better. I know, I know they are junk and throw away. But besides that any idea’s?
Cuda Ken
I believe it is Talgo. I think I have essentially the same trucks on some little red ore cars, and they are about as useless as…you got it!
What type problems are you having? You have replaced the wheels and axles, and moved the couplers, so there is not much left to go wrong. Are they bent? All they have to do is hold the wheels in place and hold the car up. On real railroad cars, the bodies just basically sit on the trucks.
I do not like to jump to conclusions, but it sure sounds like you have trackwork issues there buddy. Crappy cars will roll okay on good track, but a Division Point locomotive wll have trouble with crappy track. In fact, in many cases, the better the locomotive and/or rolling stock, the better the track HAS to be for the to run right. I still have a few cheapie cars (like $1.00 each, years ago) that still have the push-in split stud mounting talgo trucks, with couplers on them, and some have not even had the wheels replaced, and they run fine. Not at all prototypical, I bought a lot of coal hoppers and painted them black and decalled them N&W to get a big train together years ago, and I still use them occassionally, or I did until I moved. They do all have knuckle couplers in the truck mounted boxes however.
I would make me up a test car or train, ideally a too light Bachmann or Rivarossi 85 footer passenger car, or 5 or 6, with some of the skinny scale width wheels, and KEEP the truck mounted couplers. When you can PUSH and pull that around the track at a pretty good clip (ideally with a tight eight coupled steam locomotive - in reverse) with no derailments, your trackwork is 95% there. Seriously, good trackwork is the very first think to strive to achieve so you can enjoy the trains and not always have to be be problem solving. Took me awhile to learn this when I was starting out, but my first engine was a brass 4-8-4, and she was a tough teacher. But, when I made her happy, everything else was too.
Good luck.
Ken,
You need to remove the Talgo truck and plug the large hole. You can use a plastic rod. Drill and tap the hole for a 2-56. Mount the top of Kadee #5 box over the hole. Then get some Athearn or Walthers trucks at the LHS. You will now have the same basic setup that Athearn uses. I used this method to fix all my Tyco and LL cars. This change, along with body mounted Kadees, wheels in gauge and good track work will go a long way toward reliable operation.
Jim
Ken, just because it’s a talgo truck doesn’t necessarily mean it’s a poor quality one, however most of them made for train sets in the 80’s or later do fall into this category. The talgo design dates back to early days of model railroads to allow the cars to run on sharp trainset curves. Yes, I’m old enough to remember 18 inch, and even 15 inch radius snap track. For a time, Tyco had a good rolling talgo truck made of Delrin (and later Selcon) plastic. They were available as aftermarket parts in a plastic blister pack with a pin to allow pushin installation (most trucks were screw mounted back then). The easy way to spot these is they are all plastic, except the axles. These date back to the late 60’s and early 70’s. Kadee even makes an adaptor to mount the #5 style coupler in the existing pocket.
http://www.kadee.com/htmbord/page146.htm
If you have these and object to the talgo feature, the coupler arm can be cut off and the coupler body mounted.
This method works great on the old Eastern Car Works P70 coach kits. The stock screws aren’t bad, but I thought they left too much “flop” in the trucks. Plus, if you use a red Kadee washer to raise things…the screws aren’t long enough! On these cars, I also replaced the wheelsets with metal ones, and body-mounted the Kadees.
Do you mean the wheels are falling out? If that’s it, I think there are a few manufacturers that make special length axles that should fit.
Now if you’re talking about IHC trucks…well…about all you can do is replace those. They have holes that only the IHC wheels will fit in. Needle point bearing axles won’t fit.
get rid of the talgo trucks…they’re gonna be nothing but trouble…here is my webpage site that explains step by step instructions with pictures how to fit a car with new trucks if you won’t mind checking it out…explanations are in the lower right hand of the picture and just click the next button to go thru the series of pictures…i know i’m showing how to mount kadee bettendorf 50 ton trucks in the pictures but atlas or intermountain make better trucks than the kadee trucks…the kadee truck is too springy and can cause derailments if they hit a turnout just right…chuck
http://community.webshots.com/photo/137793353/1300555227055249160CpifsB
What is a IHC truck?
Main problem is some no longer fit tight. Seems very lose and few want to sort of fall off. Plus a few I messed up when I tuned them, much better at it now. Need to find some to fill the bosster’s so I can re drill.
Ken
Jim, I have no idea what you said?
“You need to remove the Talgo truck and plug the large hole. You can use a plastic rod. Drill and tap the hole for a 2-56. Mount the top of Kadee #5 box over the hole”.
From what I have read it sounds like I need to plug the truck hole and mount a coupler box on them?
Soory I not that bright yet, but I am learing.
Cuda Ken
IHC= International Hobby Corporation, a brand of models that used to be called AHM (Associated Hobby Manufacturers). They used to import a lot of Rivarossi and other European made models. Not sure what they have now.
Several good ideas on how to replace the trucks above. These cheap Bachmann and LifeLike cars are excellent candidates for weathering and improvments. They will never be as good as some of the more accurate higher priced models, but they can be made to look OK. They are great to practice on and to develop your weathering skills. Most of them also need some weight in them to bring them up to NMRA specs. The extra weight when combined with the metal wheels makes a huge difference. For the coal hoppers, I make coal loads. For the gondolas I have been making rusty metal bales out of cubes of crushed aluminum foil. Tune them up, dress them up and be proud of your accomplishments.
Ken,
You have it right. The top lid of a Kadee #5 box gives a collar for the replacement truck to ride on. Remove a Athearn truck and you will see a collar molded into the underframe for the truck to mount to. That is what you are trying to achieve by plugging the large hole and placing the coupler lid over the hole.
I can think of one good use for the Tyco talgos, they make great projectiles. [:D]
Jim
KEN:
  1. You ask for assistance, help, “ideas”, but don’t really take them.
  2. You “know they are junk” but want to make them better?
TALGOS: The PROBLEM is their design! They push the wheels off the track.
‘Push pins’ are loose - axles fall out - and you want to make them better?
TIME and MONEY spent on poorly designed products is correcting someone elses mistakes. THEY’RE also CHEAP! Perhaps ‘Scotch Tape’ is a better answer.
(Better buy a big roll).
I think in oue of your earlier posts you showed what looked like a drag car you are or were working on.
If you were to put say 13" wheels and 5" wide tires on such a car, could you post some quick ETs at a drag strip? Certainly not. If the power can’t get to the ground, using or trying to fix up the teeny tires won’t do you one bit of good no matter what you do.
Talgo trucks come with toy train sets because they are cheap to produce and assemble. Most toy train sets are thought of as being disposable - kids get tired of them before too long and they are junked. Keep this in mind when trying to spruce up your talgo trucks.
Bob Boudreau
(former drag race photographer)
FWIW Kadee makes very nice talgo trucks, if you don’t want to do a lot of work on the cars that might be a solution?? I used a pair on a track cleaning car I have. Yes, body mounted is best but the Kadee talgo’s work fine.
On the small tires on a drag car, well that is why I asked this question in a away. If all I could afford a small say 5" wide tire, I know that a lower tire pressuer will help hook up. Do a burn out at say 25 PSI and look at the contact patch on the payment. Go to say 23 PSI and repeat, go to 20 PSI and do the same again. When I see the best contact patch, I know I have the best traction I am going to get. Rather have 15" slicks, but some times you have to run what you brung.
Don, beleive it or not I have been listening, I have been cutting of the stock coupler boxes on the TALGOS trucks and going with Kadee’s. Up grading wheels and tuning trucks as I can go.
I think I may have a idea to make the Talgos fit tighter and will test later. If the washers that are made to rasie the cars weight on Athearn will fit the neck of the Talgos push pin that will take out some of the slop. With shell off, use say a rail nail or some scrap to shove into the slot of the mounting pin with a little gule. That might help some what.
By the way, on the small tires again, I forget the class it is called but there in one that limts the tire to 8" max and must be DOT aproved. They can cut 10’s. That is Zero to 120 MPH in 10 seconds. That is Hot Rodding.
Thanks for all the help folks, sorry I don’t want to stop beating on the dead horse, but I think that is how they invented PCR.
Cuda Ken
Talgo trucks? That’s like runing stock valve springs on a roller camshaft and wondering why the springs break. Good grief. No wonder you’ve been having derailments.
OK, so you have installed body mount Kadee couplers and put in metal wheels and the car still derails? And the trucks have those snap in pins that just aren’t tight enough? You can replace the snap in pins with machine screws. Remove the trucks. Fill the truck mount holes with plastic rod (you must have some sprue hanging around that fits). File and sand the bottom of the truck bolster flat and smooth. Select the largest pan head machine screw that will fit the mounting hole in the truck. Center punch and drill the bolsters to accept the selected machine screw. I have used screws as big as 6-32’s on IHC passenger cars. Tighten the screws until the truck begins to bind.
If the car still derails check the weight (1/2 ounce + 1 ounce per inch of car length). Check the wheel gage. Even good quality metal wheels are sometimes out of gage. Clean the wheels, sometimes a bit of crud is stuck to the tread. Check coupler height. The Kadee gladhand may be snagging on turnouts. Check WHERE the derailment occurs. If you go on the ground and the same place all the time, suspect a trackwork problem.
Couldn’t Ken:
YOUR Prolem is threefold.
  1. You bought a bunch of equipment that doesn’t work well -
  2. You don’t have the knowledge on how to to fix it -
  3. You are frustrated - who wouldn’t be?
ALL THE ABOVE IS FIXABLE - if you think it worth the trouble and cost to do so. Therin lies the rub.
You will need to correct inherent problems and correct them individually - by aquiring some tools and learning to use them. To wit: Kaydee and NMRA gauges. Both come with instructions, plus both have Web sites.
  1. If your track has flaws: correct them. Or nothing will work right
  2. Cars with body mounted couplers: convert to KD’s with correct heights. You have been sent posts on how to do this.
  3. Establish a standard for trucks.Trucks’ include wheels, axles, and sideframes. These have to match as the combination affects rolling. I recommend a set of Kato and Atlas 33" freight trucks for comparison.
  4. Cars with Talgo trucks: are often cheaply made. Cutting off the coupler pocket and mounting a KD #5 may not be enough. I would suggest saving these for last. Any cheaply made care will roll well with weighting and good trucks added. With new cars available for $15 today, are yours worth it?
  5. ENGINES bought off of Ebay are ‘Garage Sale’ and too often come with other people’s problems. Want EXAMPLE?: … if you sell your equipment.
Your history of purchasing tells me you have earned PT Barnum’s famo
