I recently got a bachman 2-6-0 and tried to set it up on my SCE Power Cab. After getting nothing but noise, no movement and the headlaight only on, i went down the reset path for the NCE. While the loco did make all of the same “noises” on reset and re-assigning, it’s still just making noise and not responding to any commands. what have i done wrong here?
Did you try operating your locomotive on address 3 before you originally addressed it? It’s always good to verify that first to make sure the decoder is working properly.
When you say “noise” do you mean the sound of the steam boiler?
Did you reset the decoder or the Power Cab throttle?
Another thing, the decoder reset option on the PowerCab menu ONLY applies to NCE decoders. Don’t use that to reset other brands, it could set unexpected CVs.
ANd if it indeed did reset, then the address is still 3. How are you entering the address? The default address on the decoder is SHORT ADDRESS 3, you need to select that differently with NCE because NCE can use both short and long address 3 and they are NOT the same. Select loco and jut press 3, NOT 03, or 003. Just 3. That will select short address 3.
its definitely NOT steam boiler sound- it’s just a constant noise. I did the reset of the power cab itself. when the cab/controller is sending info to/from the locomotive, there are definitely sounds like what ive heard on the programming videos.
I just tried seeting it as “3” and had no luck.
when done programming, the locomotive lurches forward a little, but the cab does nothing to control it. the headlight is the only thing that is on.
Did your Bachman 4-6-0 come “DCC-ready” or “Sound-equipped”?
Is the noise more like a buzzing sound?
If “DCC-ready” then it doesn’t have a decoder installed in it. If “Sound-equipped” then it has a Soundtraxx Sound Value decoder installed in it.
The literature states that it is “compatible with conventional DC-powered layouts”. I’m assuming that means you don’t need to swap a jumper on the decoder board before operating it in either DC or DCC?
the sound is indeed a buzzing sound, but you can hear it make different noises when the Cab is “talking” with it. how would i be able to find out if it’s “sound equipped” or just DCC? and wouldnt I be able to make it run with the NCE Power Cab w/o sound either way?
I have indeed had other DCC/sound equipped locos running with this same Cab- I had a walthers HO diesel that fired up and ran perfectly straight out of the box with all of the bells and whistles (literally)
I think i screwed up. im looking on Bachman’s website and #136, which i have, says nothing about DCC. however, #138, does state that it’s DCC.
****. I guess it’s “find a decoder” time. Thanks for all of the help, everyone. Its frustrating not having the right information online when you purchase something like this.
Did you purchase the locomotive yourself? Do you still have the original box?
The buzzing sound is reminiscent of a DC locomotive operating on a a DCC layout. The best way to confirm that is it remove the screws from the tender cover and look inside. If it did come with a decoder then it’s a sound decoder. If you see an empty 8-pin NMRA socket then you need to add a decoder.
