JMRI and QSI
I recently downloaded JMRI and im having trouble getting it to read my QSI equitped altlas. Is there a different way to do the qsi decoders. I have no troubles from the other locos i have done.
Jonessy
If the QSI is a sound decoder, you most likely need a programming booster. This increases the programming track current allowing you to read most sound decoders. Non sound decoders don’t need a booster.
If you have an NCE Power Cab DCC system, you don’t need a programming track booster. It has enough power to read sound decoders, but you need to be in program track mode.
A Digitrax PR3 in stand-alone programmer mode will also read QSI (and other) sound decoders.
Well i guess i should have put a few moore info I do have and NCE pro cab system and and it is a QSI with sound. I could not get to recongnise it on the programing track. I had to do it on the main and had no trouble making changes to it
I do thank you for the reply
Jonessy
