Apparently Windows 11 does not use or access com ports. That makes it a little difficult (read impossible) to connect to JMRI. Has anyone come up with a solution or fix? Thank you
I have a 2-yr old laptop running Win 11 that was upgraded from the Win 10. I donât have any issues connecting to or operating JMRI 5.6. And my laptop is using COM3 for a port.
What version of JMRI are you running?
My (very old) layout laptop needed to be replaced. I was walking thru Staples one day 18 months ago and checked out their laptop table. I couldnât believe what a saw. An HP 15" I3 processor with 8 gig of RAM and. 256 SSD drive for $248. I asked the tech support guy if this was correct and he said yes and I said get one to go. Anyway, got it home, loaded Java and JMRI (whatever were the current versions at the time, 18 months ago) and it opened immediately. No searching for drivers . It opens instantaneous.
Sorry, forgot to ment came with Win 11. Have not experienced any connectivity issues
It turns out the NCE Pro dcc has an rs232 port on the front that you connect to a USB port on your pc. BUT you canât just use a typical rs232 to USB cable for a printer. It had to be a âstraight throughâ also called an âextenderâ cable. Now to find one.
Glad you were able to figure it out
Hello All,
NCE makes one specifically for this purpose.
You can find them for less than MSRP at Mountain Subdivision Hobbies.
Hope this helps.
The PH-Pro has a 9-pin (DB9) serial port (RS232 is the communication protocol, but DB9 is the physical connector spec). If you have a ârealâ DB9 serial port on your computer, you would use a âstraight-throughâ serial cable (as opposed to a cross-over or modem cable). Otherwise, you need a USB-Serial adapter such as the Keyspan USA-19HS.
In either case, make sure that the connection on the PH-Pro is secure. For whatever reason, NCE uses a DB9 connector that sometimes causes issues with the cable/adapter fully seating. Folks often have to resort to fixes such as filing down the nuts on the connector, etc.
If you have the new PH5, it has a USB connector, so all you need is a standard USB cable. None of the above applies to the PH5.
Also, your original statement that âWindows 11 does not use or access com portsâ is complete bunk. Many (most?) commercially available computers no longer include them as a cost-saving measure, but Windows 11 certainly supports them.
In fact, many OEM motherboards still have the hardware provision for them, usually in the form of a header that needs only a cable like this to bring it to the outside world. Both of my self-built Win11 computers (layout computer and office computer) have such headers, although in both cases they are unused.
I was running Windoze 10 on my laptop until November when it updated to Windows 11. Since then, I havenât been able to use DecoderPro or my Digitrax SoundLoader. Using a PR4 to connect to a stand-alone programming track, and have latest version of DecoderPro and SoundLoader. Tried both ports (3 and 4), neither work, however my LokProgrammer still works fine with either. Wonder if the PR4 needs a driver or something to be compatile to Windows 11?
On my laptop, I had to force the unsigned Digitrax driver into the correct comport. That made my PR4 work as expected.
Digitrax has both the driver (Windows 8/10 worked on my 11) and detailed âforce unsigned driverâ instructions on their website.
Itâs supposed to work without doing that, but mine would not, and that fix solved the âno communicationâ issue. [2c]
Standard disclaimers of YMMV, and you get what you pay for applies.
I have Windows 11. Decoder Pro works fine. I did have to update the Java software. Have you tried reloading the software?
Simon
Iâve been using JMRI for 21+ years, and have been using it on Windows 11 with both a PR3 and a PR4 since Windows 11 went GA, and Iâve never had an issue.
As for PR3/PR4 drivers, they actually use a Microsoft-supplied driver (usbser.sys) that has been included with Windows since W2K or so. The problem was that the USB device table Windows uses to determine what driver to use didnât correctly identify the PR3/PR4 devices. Digitrax therefore was forced to provide a âdriverâ, which is actually an inf (information) file that tells Windows what driver to use. (You can browse that inf file (itâs a text file) and see that it points to usbser.sys. It also contains the Digitrax branding information.)
But Microsoft fixed that USB lookup table about the time of the Windows 10 âCreatorsâ updates, so any version of Windows after that should correctly identify the PR3/PR4 and install the correct driver. However, that introduced a new problem of âpublic perceptionâ; Now folks were concerned that when they looked at their PR3/PR4 in Device Manager, they no longer saw âDigitraxâ, but rather âMicrosoftâ.
Well, thatâs correct because now that Windows correctly identifies the PR3/PR4, the Digitrax-supplied inf file, and thus the Digitrax branding, are no longer needed/used. So Device Manager shows âMicrosoftâ since they (have always!) supplied the usbser.sys driver.
P.S. If those folks who used the Digitrax-supplied âdriverâ (inf file) dug deep enough into Device
I searched Digitraxâ website and didnât see the âforce unsigned driverâ anywhere?
My situation is Iâve updated Java, and uninstalled/reinstalled the latest versions of Digitrax Soundloader (which says it includes all the required drivers etc. for the PR4) and Decoder Pro several times. When I put an engine on the programming track (only using Decoder Pro with a dedicated separate programming track) and try to read ID, the engine buzzes and stutters indicating itâs getting a signal, then get a 308 âno response from decoderâ error message.
FWIW Iâve using a PR3 and in the last few years a PR4 and Decoder Pro for many years now. It seems like it will work for a year or two and then stop, and I have to go in and do something to get it to work again. Iâm thinking eventually I may have to set up some other way to access Decoder Pro other than the PR4.
If you are getting 308 errors in JMRI, you donât have a communication issue between your computer and the PR4.
The 308 error is issued after your command station tells JMRI that the decoder isnât responding as expected, which means that your PR4 has to be talking to your computer!
You need to look between the PR4 and the decoder: Insufficient wiring or poor connections to your programming track, dirty programming track or loco wheels, dust/lint on the wipers (older Athearns are notorious for this!), bad wiring between the loco and the decoder, etc.
You arenât using older MRC decoders, are you? They donât support readback. MRC didnât include it in their firmware because they felt it wasnât ânecessaryâ. Maybe not, but just about every other decoder brand afforded you that âluxuryââŚ
Well Iâve checked and doublechecked the wiring and that. I mean, Iâve been using Decoder Pro for maybe 7-8 years so I kinda know âthe usual suspectsâ to check. Iâve tried several locomotives with different brand decoders, cleaned the programming track etc. and nothing seems to matter. Given that the problem started when I upgraded the laptop from Windows 10 to 11, it would the problem is somehow related to that, like a driver needed for 11 not being there anymore or something.
p.s. Iâve also tried connecting up the PR4 and programming track through a programming booster. Only difference there is when I try to read the engine ID it comes up â255â and if I use Soundloader or Decoder Pro to read CVs, it reads all of them as 255. Thatâs part of why Iâm pretty sure the signal is getting to the decoder, itâs kinda like when the signal gets back to Decoder Pro itâs scrambled - or maybe the signal gets to the decoder, but itâs scrambled some way?
I still think youâre barking up the wrong tree by blaming a driver issue. As I noted in my previous post, the PR3/PR4 have always used the Microsoft-supplied usbser.sys. I also pointed out how to verify that Digitrax was pointing to that driver by examining the inf file they provide, and how to verify thatâs what your device is actually using by drilling down in Device Manager.
In addition, I pointed out that the 308 error in JMRI only occurs when your command station (or stand-alone programmer) reports back to JMRI that the decoder didnât acknowledge as expected. That âreporting backâ couldnât happen if your PR4 wasnât communicating. Youâd get a 306 if JMRI couldnât âtalk toâ the command station/programmer. These error codes are all documented on the JMRI web site.
[quote user=âwjstixâ]
Yes Iâm using the Digitrax âwall wartâ with the PR4, itâs worked fine for maybe several years up until now.
An earlier reply indicated that the problem could be with the drivers.
I will check all the connections again, but I still think it an odd coincidence that everything worked fine until the Windows 11 upgrade. I suppose itâs possible a wire or some connection just happened to go bad that same day, but it seems a bit unlikely.
But stranger things have happened. [;)]
Since nothing else has worked re hardware, I tried hooking up my old PR3 and got a result similar to the OPâs original issue - COM3 simply disappeared. I may try uninstalling and reinstalling everything one more time, and if that doesnât work, may search around for another, simpler device (i.e. one that doesnât need a 10 page instruction sheet) to connect the programming track and my laptop.
Did you select COM3 just because itâs mentioned in some instructions somewhere (which folks often do), or did you confirm the correct port in Device Manager by plugging/unplugging the device?
On my layout desktop computer, my PR3 is COM3 and my PR4 is COM4. But on my laptop, the PR4 is COM3. I donât use the PR3 with the laptop, but Iâm willing to bet it would use COM4 if I were to plug it in. So confirming the correct COM port matters.
However, if your COM port is truely âdisappearingâ with both the PR3 and the PR4, itâs likely that itâs not the device itself. Bad USB cable, power settings in Windows âturning offâ the USB ports, etc.
COM3 only disappeared when I tried using my old PR3. It came back when I reconnected the PR4.
Iâve been using COM3 for the PR4 and COM4 for my LokProgrammer since I bought the laptop a couple of years ago, no problem with either before Windows 11 update.
Device Manager basically says something is connected to COM3, but doesnât specify what.
