Kalamazoo Toy Train models
When I was a kid, my parents took me to a toy train factory in Bangor, MI called the Kalamazoo Train works. I seem to remember it being located in a train station, and that they primarily manufactured an American General 4-4-0. I’ve seen a few on eBay and have wanted to pick one up.
Does anyone know if they are any good?
Did this company go out of business?
Thanks!
When Kalamazoo went out of business, I acquired a caboose and a gondola. Not too detailed but they work fine, weren’t costly although not as heavy as LGB cars, and were robust enough that I didn’t worry about the kids. The girls have finished college and moved away but the cars are still in first class shape. Hartland had a close out on their gondolas, same molds and everything, so I added three more to the fleet. All have the same car number (different from Kalamazoo) and some day I’ll do something about that.
Art
I have one Kalamazoo combine car and I can’t say anything bad about it. Acceptable detail, tough as nails and not too expensive and MADE IN USA. I wouldn’t hesitate to buy more in the future if one comes my way.
Forgot to mention a neat thing about the Kalamazoo/Hartland gondolas. The sides, a one piece molding, are removable; they have prongs on them that fit into the stake pockets. Once the sides are off, it is a flat car with stake pockets and NO NAME or Number. So it’s easy to add whatever markings are wanted.
They are very light weight, though, but even the full scale guys put empty flats at the rear of a train to prevent ‘straight-lining’, so the light weight is not a show-stopper.
Art
I have never heard of Kalamazoo. Learn something new everyday.
Thanks for all of the updates. I always did like the colorful red/green MCRR 4-4-0.
I recently came across an old Kalamazoo catalog I had when I was a kid, so I thought I’d inquire… Kalamazoo TT used to leave Mini-Catalogs at Holiday Inn’s scattered around Michigan, so whenever my family was on a trip I’d pick one up. I still remember the factory tour, small staff, all hand built/painted trains. They basically made two engines, which they painted many different ways to give the impression of a “full locomotive line.” But this was before LGB made American prototypes, and Delton was just getting started.
I’m glad to hear that Hartland is renewing the old Kalamazoo line and that they are still made in the USA…
The best way to fix “streight lining” on anything is to but a five gal tub of leadputty (you WILL develop a few henias tring to lift the stuff) and add a half inch layer to the bottom.
I have three that have been running around the Christmas Trees for hours on end every Christmas season since 1984. The only problems I’ve had are not related to the locomotives themselves but accidents or modifications. They only pick up power on the 4 driving wheels. This is not usually a problem but I used one wheel as a cam for PFM sound. That left only one power pick up on the one side so it began to stall on turnouts with an insulated frogs. I fixed it by adding metal wheels with pickups to the leading pilot truck. I also added a fairly strong piano (spring) wire to the truck so it actually turns the front of the locomotive into the turn.
I can highly recommend them for their running quality and durability. They are obviously narrow gauge and not a model of a prototypical locomotive, if those are important to you. I have not run them outside, but as I recall they were designed for it.
Java an old 440 Kalamazoo set I would like to DCC/sound To adapt it to my existing garden RR. Did you ever try to access the weather-proof motor enclosure? Can’t figure it out. Great design though. No wonder it runs like new after 30 years!
Yes they went out of business but got picked up by Hartland Locomotive Works and are going strong, the engines have under gone alot of change and seem to be of excellent quality. Read the post I did on the Phil Jensen story which gives you an idea on the history of the company and Phil still works at Hartland on Tuesdays and Thursdays. I have one of the original motor blocks that I can’t tell the defference in between it and a LGB block.
Do you have any pictures of the mmotor block, I have an old one but it looks the same as an LGB, Bill
I first saw Kalamazoo trains at the local ACE hardware store. They put out one heck of a Christmas tree village and several trees had those trains circling underneith. Never convinced my parents to get me a set back then. But once I had my own source of income, I put the MCRR 4-4-0 at a train show and the full consist of the tan/green coaches that I have relettered for the Autism Express. I converted the locomotive to battery power, which did away with its power pick up issues. I got to meet Phil Jensen at the National Garden RR show when it was in Cincy a few years ago. Many of the older Kalamazoo engines have split axle gears, but the new ones from Hartland drop right in. I have plans to purchase more of the Kalamazoo/Hartland line as it fits my logging theme my garden railway is evolving into. Cheers Mike the Aspie
For those wanting to open up the motor block, its a “clamshell” design like the early LGB ones. You have to remove it from the model, remove the side rods, then remove the drive wheels(be careful as there are sprung pickup brushes behind those wheels that can go flying), then there are screws to remove. After all that, the block will open up with a little light prying with a small flat blade screwdriver. Mine used Globe brand industrial motors(also made in the USA). My venrable old MCRR 4-4-0 just put in nearly 6 hours of continious running yesterday at the Austim Ability Fest in Indianapolis, pulling my 3 coach passenger consist. Which is at the limit of the engines traction. Only down time was 30min for a battery recharge(mine has a 7.2vt, 5000mah Nimh battery in the tender). Hartland took some of the improvements from the Delton C16 like the headlight and cab tooling along with better domes and upgraded their 4-4-0 as we see it today. I just wish they had retained the more correct tender trucks that Kalamazoo used. The freight care style trucks just look out of place on the current models tender. I always pick up Kalamazoo stuff when I find it. Great for bashing or leave it like it is. Their wheels are very quiet running(important to someone on the autism spectrum). The early folks at the event(before it got noisy in there) commented on how quiet the train ran. The noisy 3 rail train they have wasnt very enjoyable for their autistic son. But he loved my Kalamazoo set! Here is a pic of my display(I also took my Marklin HO portable setup). Mike the Aspie
Just before the event opened, the Colts, Pacers and Indy Fever set up in that open area behind us. My wife is sitting at the far end of our display
Shortly after opening, after that it got to busy to do anything but run trains and answer questions about where to get them as many h
Mike,
Thanks for the history lesson and practical tips. Also, thanks for your community service! That is really special what you are doing.
On another note, yeah, I am shocked how few people know large scale exists, let alone that it is outdoor capable, and, if you are lucky, not always much more expensive than a starter set of any quality in a smaller scale.
Aloha,
Eric
Many of them didnt know much exhisted in large trains other than the cheapo plastic ones you find during the holidays with plastic G gauge track. Several are now hunting down either LGB or Kalamazoo sets for thier sons thru a couple online sources I recommended for them to look at. Hartland really doesn’t have much for sets at the moment on thier site, and second hand is normaly much more affordable for a family dealing with a special needs child. My set up was very popular as I did not mind if the kids touched the trains. First and foremost they are toys and ment to be played with. My wife and I really enjoyed our day letting others enjoy our trains. Mike the Aspie
“First and foremost they are toys and ment to be played with.” This is an admonishment I remind myself each time the old iron horse come off the shelf!
Hello, I have looked and I don’t see any information on posting or advertising stuff here, so if this is violating some rule, please let me know and or delete it. Or better yet, if you could, suggest a better place to do this.
My father was was one of the founders of Kalamazoo Toy Train and helped design and build most of their stuff in Kalamazoo and in the old train station in Bangor. I have a big tote of old stuff that is looking for a good home. Some cars, one engine/locomotive, and a few miniature pieces for layouts.
My family would love to see this stuff go to a good home where it would be used and appreciated. If anyone is interested, please reply here and we can sort things out.
Thanks!
Don
Hi Don,
As far as I know there isn’t a marketplace on this forum. There are on others. I will reach out though about possible homes for the equipment.
Thanks,
Casey
I think part of the problem is that it has changed so many times. That gauge track was called “Number 1” gauge by Marklin in the early 20th century; they offered several sizes of trains/tracks with No.1 (1-3/4" gauge being the smallest). Standard gauge No.1 trains use 1:32 scale. (BTW “O gauge” started out as “0 (zero or zed) gauge” when Marklin made a smaller 1-1/4" gauge.)
“Large Scale” or “Large Gauge” came to the attention of most US modelers when Charles Small wrote an MR article in the early 1970s on his “Lake George & Boulder Ry” using the LGB trains he had brought back from Europe and ran in his backyard. These trains were based on European meter-gauge trains, with a scale of 1:22.5.
In America, it was suggested that No.1 gauge be re-branded “G gauge” for LGB trains and for Garden railroads. (BTW in England and much of Europe, your “garden” is just what we would call a “backyard”, so it’s a “backyard railroad”. It didn’t mean you had to run it through flowers and little shrubs etc.)
Here, we didn’t like the scale, so went with 1:24 or 1/2" = 1 foot. I believe the Kalamazoo trains were made to this linear scale. Eventually, products started being made in the US to 1:20.3 scale, which made the 1-3/4" gauge track work out to 3’ gauge, the most common US narrow gauge.
The problem that developed is that 1:32 standard gauge trains and 1:24/1:20.3 narrow gauge trains weren’t the same size, but ran on the same track. This lead to the production of 1:29 scale trains, which allowed Garden railroaders to more easily mix and match with the other sizes. This has become the most common scale for standard gauge “G gauge” trains.
I used to subscribe to an old magazine called A.W.N.U.T.S. - Always Whimsical, Not Usually To Scale, which had Kalamazoo ads in pretty much every issue, and had many photos of their trains on layouts. I felt bad when it went out of publication; I appreciated the fun and humor of ‘playing with trains’.
