Hi all,
I’m in the process of wiring a keep-alive capacitor into a TSU-750 I’ve installed in a HOn3 brass C-25 locomotive. I’ve had to put the 220uf capacitor that came with the decoder on the outside (under the chassis, disguised as a brake cylinder), but I have space for a smaller capacitor in paralell with it inside the tender - this would have to be smaller. My question is would the extra 100uf (I think this is the biggest that will fit in) make a difference in terms of keeping the decoder alive over trouble spots?
Thanks in advance,
tbdanny
As an old electronics technician, I would say Yes. Make sure the polarity matches. Plus to plus and minus to minus. You want them to be in parallel.
I would have to agree, 320uF is significantly more than 220uF An investment in additional pickups would probbaly give more dividends - if there are pickups spaced nearly the entire length of the engine and tender then even a small loco would span a large number dead frog and if your track is reasonably clean shoudl never ever stall or have the sound cut out.
Here is more info about keep alive.
http://www.members.optusnet.com.au/mainnorth/alive.htm
Litchfield Station sells SMD caps which might be a little smaller.
All wheel pickup on the tender and loco and clean track solves a lot of issues. When I say clean, not looks clean but you have actually done the cleaning process.
Most want as much capacitance as possible.
Elmer, Randy and Rich,
Thanks for the replies. I’m already adding extra pickups to the tender (loco already has them). I’m just trying to squeeze every last drop of reliability that I can get out of this locomotive.
Cheers,
tbdanny
Try using the surface mount capacitors. They are very small. At 100uF you can tie them together and make a 400uF cap if you use four. Some times you can find room for two surface mount caps in one end and two more some where else. Just wire them in parallel. If you have more room add some more.
