I’m putting together an N scale Maintenance Platform Kit from N.J. Int’l. The instructions recommend coating the very fragile handrails that are part of the kit with “ketone” in order to strengthen them against damage during assembly. I googled “ketone” and only found links to chemical, dietetic and urological information. What is “ketone” in a modelers world?
Another ketone is acetone. Acetone is the simplest ketone. Both MEK and acetone(Dimethyl ketone) will disolve or seriously soften most plastic products. Dangerous if inhaled or placed on skin. I don’t see how any ketone would make plastic stronger.
I had a question re: an NJI signal and called, left a message. Nice man called back and answered the question. I suggest that you call and ask about the ketone, and the concern that the parts would be affected. Number is 480-219-4185. Oh, and let us know what the answers are.
Previous responders are correct that ketones are a class of hydrocarbon solvents. Acetone is the simplest ketone. Methyl ethyl ketone and methyl isobutyl ketone are commonly used solvents. Additionally diacetone ketone is another ketone used in some paint formulations as a solvent. One route to manufacturing acetone uses isopropyl alcohol commonly known as rubbing alcohol as the raw material for producing acetone. Cody Grivno frequently recommends using isopropanol as a wetting agent for ballasting. Acetone is sold in a diluted form as fingernail polish remover. Acetone is a good laquer solvent. Based on my past experience in the actual solvent manufacturing business I would be doubious that any ketone could be used to strengthen small plastic parts. Rather, ketones would dissolve most styrenic plastics. PVC is attacked by ketones. ABS is attacked by ketones. Polyethylene is mostly resistent to ketones.
When I was purchasing SLA (now called 3D printing) parts for a client, they were dipped in Acetone for a few seconds ONLY, to give the parts a smoother surface finish. I imagine the Acetone actually disolves the surface layer momentarily and then evaporates, leaving the surface with a shiny/smooth finish. With SLA parts there is a stair-step surface to it as a result of the manufacturing process. This was about 8-9 years ago and SLA process has probably improved somewhat since then. This may be what the ‘coating’ does to the handrails? Just a suggestion to a possible explanation.
Oh I totally agree with both of You…that review was five months ago.
I have found that kits others complain about, I don’t find that bad. Especially the one’s that require more reading, than pictures. I can see though that in N-scale, those railings could be a challenge, if they are in fact scale plastic. I was actually trying to find instructions for that kit, when I found the other. I was wondering if the railings were Derlin, not styrene. Then I could understand the use of Ketone.
I got a call back from NJI and was told if I use a practically dry-brush method of applying ketone to these plastic railings that it will soften them enough to make handling them without breaking them more likely. This was the gentleman that wrote the instructions. He also said “don’t worry if you screw it up, I’ll send you some more railings”.
He said I should be able to get ketone, or any other product like it at a hobby shop. Doe anyone have a trade name for this or is ketone it?
Like anything else, buying in a large quantity generally is less expensive. However, if the only application is to dry brush some N scale handrails, what is one to do with the other 127.995 ounces? I think we should answer the OP’s question as to what he can buy at the local hobby shop.
One has to have everything served right up instead of looking up things or even reading the labels of the contents on the back of the bottles of Glue at any Hobby Shop!
But - to answer the question!
Plastruct is the brand but as Quoted above
IT IS WAY TOO MUCH even then buying a single bottle of Glue at the Hobby Shop
IF doing only the Handrails - even the smallest bottle would last the OP 10 lifetimes!
So he needs to find a friend that has some so he could not have to spend unnessarily - we surly wouldn’t want that - would we?
