I recently got a rebuilt KW which works fine but the hum is a little too loud for me. I don’t want to spend more money to have this issue fixed but was wondering if spray coating a ruber coating on the inside of the case would reduce the noise to a reasonable level. Would this cause an overheating problem or other problem? Does anyone have any other ideas or thoughts? Thanks in advance
Do you live in the Schenectady NY area?
If so, maybe you can bring your KW transformer to the train show that is going to be held at the Albany Polish Community Center on Washington Ave extension next saturday (3/19). It is right by Crossgates mall.
According to what I have read, there will be a “Train Doctor” there. Perhaps the doc could look it over and give you some advice.
I would not use a spray coating as it may not let the heat escape from the transfomer core and secondly you might over spray and kill the electrical contact area for the roller arms to pick up voltage.
First see if the mounting screws are tight enough or may need replacing.
removed the cover. there should be 2 small wooden wedges opposite each other on the coil lamanations. tap these in gently until tight enough to stop the humming. there are also 4 tabs on the aluminum frames that hold the coil. these are angled. you can bend these in slightly also to help stop the humming.
I have repaired several that had them. (ZW’s also) Not all will have them. Also in the several LIONEL postwar repair manuels that I have, it is mentioned in the transformer section. the lamanations are not riveted together. the windings are supposed to be tightly wound around the fiber bobbin to keep the laminations tight so the 60~ dosn’t make them vibrate or Hum. Over time some will work loose and make the noise. so Lionel recommended a small wedge be installed to tighten up the windings and reduce the noise. usually it’s the primary winding that makes the most noise.
