I’m about to start laying flex track for the first time…what suggestions do y’all have? I have used it on long straights before, but never in curves yet. What tricks and tips do y’all have for laying flex track?
Rotor
Rotor
know your brand…surf around this forum and they’ll be alot of info about the negatives and positives of different brands of flextrack. nice rotary engine.
Slide one rail 1/2 way to start with. If you look at the real R.R the never have rail joints together. I slide on rail and keep my joints at least 1 foot apart. This helps in turns. It can get a little difficult at times because you a working with 2 pieces at one time. When you come to a switch just cut off the long piece and use it to start on the other side.
http://www.trains.com/Content/Dynamic/Articles/000/000/004/379dcjrm.asp
http://www.trains.com/Content/Dynamic/Articles/000/000/000/110kfhum.asp
2 links on the MRR site to look at.
I just spent the last couple of days putting in all my flex track. I have to say, despite all my reading, you have to do it to get good at it. My leasons are many, here are the obvious ones:
Its not that hard to fix and replace. Only solder on the outside of the rail. Use lots of flux and a hot iron. They say to remove two ties on each end but I cheat alot and its not so bad. Its fun and you have something when your done. You will have to adjust some no matter how careful you are.
