I’m in process of kitbashing the Wathers Electric Arc building within in the steel mill section of my layout, I already completed & detailed a connecting Walthers Rolling Mill & also scratach bulit an adjacent 3 story bag house for dust & emissions control. The electric arc furnace will be the last builing within the “mini mill”. Having worked as a charge crane operator in a mill back in the late 70’s, i have fist hand knowledge of how loud an electrai are furnace can be when the high powered electrodes are lowerd down into furnace lids 3 circular openings and the electrodes meet the cold scrap, this begins the scrap melting process which in a 80-100 ton arc furnce a single “heat” can take 2-3 hours in order to acheive a tempeture of 3,000 degrees, this process will also require mulitple loads of scrap steel bucket charges over the same period of time before the funcace “heat” can be tapped out into a very large hot ladle pot. As many of us RR modelers continue to seek realistic operations on our layouts, i decided to add a high intensity blue & white flashing kit (3mm leds) & a high intensity (3mm orange-red flame simulated (fire kit) inside the arc furnace itself, real life expamples of which can be found on Youtube videos. The last element of true operating realism i was missing was SOUND, after some reaserch i was abel to find professionals who can assist me with recordings on stock or custom sounds insatlled at my choice on board chips / and also mini high intesity speaker systems. The companies assting me with the sound electronics are Pricom Design, Fantasonics, & Scale Sound Sytems.
Lastly, in my opinion when considering adding sounds to a model RR layout, and there are many pre-recorded sounds to choose from, not to mention custom sounds as well, one has to keep in mind that our hobby is really all about running & operating trains, as the engines also sound. Bayway Terminal NJ &
