LED help for headlights
hello all whats size do i need for headlights i have 3mm n 5mm are they any good or do i need smaller ones also how bright can i get them or is it best not to bright ??? im into ho scale an am using dcc ( Lenz ) if that helps out thanks … [:D][:D]
Size depends on how much space you have int eh loco. 3mm is about the size of most light bulbs in HO - the ridge aroudn the base of the LED can be filed down if you are careful nut to go too far, for example to get the LED to fit int he channel int he frame of my Proto 2000 Geeps where the original light bulbs were, I file a flat int he base of the LED opposite the existing flat part and the LED drops neatly into place in just the right spot to shine int he light pipe. For locos with no aprticualr palce to actually put the light source, I’ll use the 5mm LEDs, mainy just to use them up. If you want to do ditch lights, then you need much smaller LEDs.
FOr the usual white type LEDs used for headlights, use a 1K resistor, Plenty bright and the current is limited to well within the LED’s safe range.
so the 3mm is good for headlights then ?
3mm is fine for headlights.
Dave
I use 3mm LEDs for my HO locomotives, as the OD of the LED matches the OD of the headlight lens.
ok then ill use those that i have thanks a lot for info
