I am using a couple of Lenz LS150 turnout decoders and have a couple of questions concerning the AC supply that is not totally clear from the manual…
Is it possible to power two LS150s from the same transformer? The manual is clear that the common “C” outputs should not be connected together, but makes no mention that the AC supply must be unique for each unit.
The manual does mention that for manual pushbutton wiring for switch machines, the common connection to the pushbuttons must be wired to the AC power terminal that is furthest from the corner of the board. If it is allowable to power two LS150s from the same transformer, I suspect that the connections to the transformer must be wired to the same terminals on the LS150s.
The other question is regarding maximum voltage. The manual just says that 16 V is the maximum. I am using a Hammond doorbell transformer rated at 16 V and 40 VA. With no load on the transformer, its voltage is more like 19. The manual does mention that if a transformer has a VA rating over 45, then a 10 ohm resistor should be used to limit current. I am wondering if a resistor should be used in my case. The units work fine with this voltage, but I am wondering if it will take its toll over time (things generally are engineered to take maximums over their documented values, but performance or lifespan may suffer).
