Looking for what has worked best for others operational wise and ease of use between lift out sections, swing gates, etc… I don’t want a duck under. If you have pics, I would like to see how you did yours.
Thanks,
Fred
Thanks,
Fred
No pictures (1950s) but I had a hinged lift up section at a doorway that worked very good, just make sure to make an interlock far enough in advance killing the power to the feeder track to the big drop to prevent an accident. You only have to forget once and you’ll be very sorry.
Mel
My Model Railroad
Bakersfield, California
You didn’t ask for my advice, but I’m giving it anyway. From one Fred to another Fred - just don’t. Make do without.
Building modules for modular railroads has the same problems - getting very accurate alignment between sections - in all 3 dimensions - first time, every time is an engineering work in and of itself. The solution - and there are many out there - will take your time and focus off the things that matter. As will construction and maintenance of whatever system you use.
In evaluating what system to use, allowable tolerances matter. A 3rail O section joint can have a lot more tolerance than N track. Other evaluation criteria include acceptable tolerance in all 3 dimensions, impact of humidity and temperature on the structure, and maintenance of tolerance over time. Also, constructability and ease of use are factors.
Tight fitting hinges can give close fit in 2 dimensions - but common hinges are not necessarily tight enough for model trackwork. Hinges have the advantage of probably being the easiest solution to operate because you are pre-aligned in 2 of the 3 dimensions. However, the further the joint is from the hinge point, the tighter the hinge must be to keep the joint within tolerance.
Alignment pins of various types tend to work well, but are not the easiest to position initially or use. Alignment pins work best with a sliding section, but again getting the 3rd dimension (gap between sections) reliably aligned every time is not simple. The advantage of sliding section with alignment pins is that the gap between sections is generally not as critical as the horizontal and vertical alignment of the rails.
A liftout can you give you pre-alignment in the vertical and section gap, but finding a structure that gives you accurate enough alignment in the horizontal while remaining easy to lift out or put back is a little more difficult. A liftout (or even vertically hinged) with fa
This thread offers a lot of pictures and insights:
http://cs.trains.com/mrr/f/11/t/278773.aspx?page=1
I have a hinged liftout, that has an HO and HOn3 track going through it. I’ve had it for 3 years now - and no derailment issues. My room is small (7X11), so it was very difficult to avoid. It was either that or doing a point-to-point layout, or going in n scale. Both non-starters for me. But if you enough space for return loops, then avoiding a liftout is absolutely a desirable option. Duckunders are to be avoided in my opinion.
Simon
Planning a tipup on my new layout. My reasons for that choice: Tip down, scenery and track are exposed to passing traffic as you go through. Lift out, you need a place to store it. Swing gate, I do not have room for a swinging gate, even if you do it takes up space where it rests. I have seen at local train shows a modular layout with a tip up that works very well, the hinges are slightly above the layout surface (block of wood under each hinge). The actual hinged side seam is covered with a piece of rug that looks like a plowed field. Could be made to look like grass. I’m sure many folks have reasons for not using a tip up, but they’ll have to tell you why.
If you go to youtube there are many examples. I found an interesting one at HO Scale Layout Lift Bridge. There are many others.
Good luck,
Richard
The challenge with lift up is the offset hinge required. Tricky to build accurately. Lift out is better and can be built to refit more accurately. Finding a place for a lift out cannot be more difficult than finding room for a lift up, geometrically speaking. Same space required, same problem but with lift out you have options to put the lift out piece elsewhere. Indeed, you don’t need to put it anywhere, just lift out, pass through, turn around, drop back in. You can even leave wires connected to one side, leave enough slack.
3D alignment isn’t as tricky as it appears. The secret is to use wedge shaped aligning parts. The dovetail joinery technique relies on this principle as do many other alignment solutions. Woodruff keys in the ends of crankshafts spring to mind. Kitchen cabinet hanger bars also, a plywood batten ripped at 45 degrees (any suitable angle will do), screw one half to the wall angle up and outwards and the other half to the backs of the cabinets other way up to mesh back as if not cut. The cabinet pieces can all be cut apart to fit each cabinet separately. Hang each cabinet and the wedge action snugs the cabinets against the wall in perfect alignment. And so on.
I have done a swing door lift bridges and a lift out section. I currently use the lift bridges and liftout section.
Above are both lift bridges in the down position. These are done by having 45 ends on each end and the pivot point is below the track level. On the left hand side the bridge mechanically keeps trains from going off the end by blocking the track. on the right side the track has a electrical cutout that turns off the track approaching the bridge for about 8 feet.
Lower bridge in up position and receiving pocket on far side
Lift out section
Here you can see 45 degree ends. the track is also on a 45 cut. This allows everything to not interfere when opening or closing the bridge.
I figured since it was a bridge I might as well make it a bridge. Eventually I will add scenery and it will be the platte river going under the bridge.
The pin is used to secure bridge in place and prevent any movement that may cause track to become misaligned and cause a derailment.
sorry that the pictures are so blurry. old camera phone.
Nothing tricky about hinges, if you don’t have to completely hide everything. Swing up - hinges go on the top, drop down - hinges go on the bottom. So long as the hinge pivot point is higher than the rail, there is no binding issue with the swing up section.
I figured that a lift-out would be the simplest to make. and since I was going to need two of them, in the same place (one on the layout’s main level and another right above it, on the partial upper level)…a lift-up or drop-down on one level would conflict with the one on the other level.
I used 3/4" plywood for both the lift-outs and for the brackets in which they sit
…and when they’re not in use, they’re not in the way either…
The on-layout track is cut back from the edge, so there’s no chance of clothing snagging on the rail-ends…
The lift-outs are not interchangeable, and the plugs on each…
Well, I don’t have them built yet, but my new layout will have two lift out sections, that can also be ducked under…
One will contain 5 tracks at three different elevations.
The other will contain 4 tracks at two different elevations.
My method of construction will be similar to Wayne’s, but a little more involved for the different heights.
Most of the tracks will be straight at the joints, but two of them will have a curve similar to Wayne’s.
Trouble free alignement is not really that hard.
Sheldon
For my best solution, see page 22 of the April, 2021 issue of Model Railroader magazine.
-Kevin
Thanks guys for the great ideas.
I have a swing gate, a lift out and a duck under all in the same door crossing. The lift out is only in place for OPs sessions. The duck under is removable but generally it stays in place. I don’t have any problems with it as it is at 60” - more of a lean under. Visitors to the layout don’t have issues with it either.
The swing gate is permanent. It has been in place for more than ten years. The track does come off of it at an angle. It does move around a bit being wood and being in a finished garage. I have noticed that the humidity moves things a little. I use a shim to hold it at the correct alignment. It has been a very convenient and effective way to enter the train room over the years.
Here is a thread explaining the build with some pictures.
http://cs.trains.com/mrr/f/11/t/127351.aspx
Here is a link to my website with no watermarked pictures and a description of the build
My current garage layout has a rather large six foot long staging/storage peninsula that sits parallel to the middle of my sectional garage door. To maintain good access to all of my garage, I made this entire staging/storage peninsula a swing out section. The end of the peninsula attached to the layout uses a 48" long piano hinge mounted vertically to one corner of the staging/storage peninsula. Small casters were mounted on the underside of the far end to take some of the weight off of the piano hinge when the staging/storage section is in its normal (closed) operational position. The piano hinge takes 100% of the weight when the peninsula is swung open as the driveway is lower than the interior slab of the garage. Slide bolts are used to lock the peninsula in its closed position.
I built all of the benchwork and installed the piano hinge and casters prior to laying any track. Once I was ready to lay track, I purposely laid lengths of flex track across the gap between the layout and the staging/storage peninsula. I removed several ties on both sides of the gap and replaced them with pieces of copper clad PC board. After nailing the PC boards to the benchwork, I soldered the rails to the PC boards ensuring that the track ends can’t move. Only then did I use a razor saw to cut the rails at the gap. I finished the rail ends with jeweler’s files to ensure that trains would cross the gaps without trouble. Power is supplied by forming the DCC bus wires into a loop at each staging level (there are two staging levels and three storage levels) at the hinge joint. I have not had any track alignment problems in the 10+ years the layout has been in operation.
I have never used any type of lift up, swing gate, etc. on a layout. If it takes some time to open the path to the exit door of the room, I would feel a bit trapped especially when the “senior bladder” calls. Could be a safety issue as well.
Looks unreliable to me. Plus, no conductivity in the rails is just asking for trouble.
The higher uour layout from the floor, the less problem a duckunder will be.
My first club’s portable layout had 36" of clearance, that is a crawl under.
My home layout has 46 inches of clearance, with a 2x4 connect to same size table legs at the best duck under spot.
A higher level would be even better, allowing to just lower your head.
I definitely have senior bladder, and while a fire is very low probability, it only takes one to ruin your day.
I would consider a lift up section. Here is a very cool one, probably very expensive but cool… https://www.youtube.com/watch?v=DNeZfmnGQgU
A simpler and much cheaper type of lift-up:
The lifting bridge is pretty cool, but even my middle-aged bladder would not be strong enough to wait that long… Jokes aside, my liftout is used pretty much like a door, so it needs to be fairly rugged. I think it’s fast enough for any quick escape… That bridge on the video might be ingenious, but in real-life, it would not be practical and certainly not be durable enough for someone goofy like me. My liftout is very similar to the one presented in the second video. The idea of re-railers on the liftout is interesting, but not essential in my opinion.
Simon
if it comes to that, I have a medical potty chair I can keep under the layout…
Until then, I will duck, crawl, sit on a wheeled stool, or lift out the section…
Sheldon
