This is an opinion question for those with street lights on their layouts. Are the lights in this picture (https://photos.app.goo.gl/oXwp16zMHiagv1wG6) too intense? This was taken with no external lights and no flash on an older cell phone without light adjustments. By my uneducated eyeball, they are. However, I don’t have a base to go from. Each light has a resistor wired to to it and then in parallel. There are three more streets with these same lights. Each street is on its own circuit that plugs into one side of a WS linker plug. The other side then connects with single wires to one side of a central plug. The other side of that central plug then connects to an Atlas Connector switch with single wires.
As usual any ideas or thoughts would be most welcomed.
In nearly every case of modeling lighting I prefer to err on the side of dimmer is better than overly bright. However there are some variables to be considered and the main one is how much ambient room lighting you will have when creating your night scene.
Having lights that are obviously too bright, unless you’re modeling a Kiss or Pink Floyd concert, will give a toy-like impression to the visitor. I’ve found that folks that peer into dimly-lit model structure rooms are more curious and tend to look longer to see the details within.
Here’s one of my street views where each lamp provides a pool of light and slightly darker areas between poles:
I remember as a kid riding in the car at night when all the street lights were incandescent and they weren’t all that bright. Watching the overhead lights always made me sleepy. There were dark, shadowy areas between light poles unlike most areas today with high pressure sodium or LED lighting providing almost shadowless light.
This car shop scene is another example where the dimly-lit areas and shadows become part of the interest and allure to the night-time feeling. A viewer wants to keep looking to see what might be lurking in the shadows.
I’m with Ed on this. The street lights running down my street leaves dark spots between them. My driveway just happens to be in the middle. But at least there’s a fire plug next to it. I installed solar lighting facing the driveway so when a car pulls in the lights come on.
I have seen model structure lighting on layouts when on light up the whole area around the structure and you can see the bracing inside the walls like an X-ray.
I model the Transition Era so I prefer the softer warm glow of incandescent lamps. I usually get 16 volt lamps and run them on a 12 volt bus. This keeps the bulbs from being too bright and greatly prolongs their life.
I start with the usual 1K (1000) Ω and I use a very accurate variable power supply to slowly raise the voltage toward 12 VDC. If I see the LED getting too bright I then substitute a 1.6, 1.8, 2.2 or sometimes even higher value.
This Coke machine has a tiny SMD LED in it and I seem to recall I needed a 3,600 Ω resistor to get it to dim enough so it didn’t wash out the signage.
The picture is extremely dim, but I suspect that is a result of the camera setting rather than the resistors. A 2.2k resistor shouldn’t have dimmed the lights by that much.
I think that you are the best judge of what looks right to you. The ideal effect would be what Ed showed in his bridge photo where there are dark spots between the lamps.
Since this is a downtown scene I’m going to assume that most of the building fronts and windows will be illumunated. My suggestion would be to get those lights installed and reduced to proper light levels before adjusting tne street lights (Ed make a really good point about lower lighting levels being more enticing). Once you have the building lighting sorted out, then adjust the street lamps so that they can be seen but are not blinding. The circle of light under the lamp is what you want to see.
None that I’m aware of [:-^] I have seen PC boards with jumper wires or bridging wires and these are presumably 0 Ω.
I’ve purchased maybe three or four of these assortments over the years from different vendors and haven’t found a 0 Ω resistor yet. I simply found an Amazon link to a similar assortment — there are dozens in various wattages and styles. I only posted that particular set as an example.
For reference I went with a different assortment than the one suggested. (http://www.ebay.com/itm/174992794630) For what I am aiming for it works.
As to the building lighting question, that is the next thing on the list for the streets. I have a few freight car projects that are redirecting the budget. The “camera” I used is the same cell phone that took the first photo posted.
So far, nobody has mentioned what I think are two key points. First, you mention you are using the AC terminals on your transformer to provide power. Depending on the quality of your transformer, you could be providing up to twice the nominal voltage to your lights. This is because transformers require a minimum current to achieve stable operation - below that minimum, the supply voltage increases. I had a very old MRC power pack which delivered 31 VAC on the 16 VAC terminals, and 26 VDC on the 12 VDC terminals. Moral: check the actual voltage. (A 2 amp 12 VDC regulated power wall wart costs about $15 on Amazon, and it will deliver a steady 12 VDC between zero and 2 amps.)
Second, some LEDs require amazingly high resistances - say, 5,000+ Ohms - before they become noticeably dimmer. An LED which nominally requires 20 mA might be nearly as bright down to 1 mA. This is very different behavior from incandescent bulbs, where brightness decreases almost linearly with increasing resistance.
As the hobby transformer I’m using was a freebie, I’m not going to knock it too much. (The lights were switched to it when I discovered that activating a remote turnout dimmed the lights when they were hooked to the big MRC pack, meaning the system is a bit overloaded.) When I have checked the AC voltage IMS it runs somewhere between 16 and 20 which is within the norm for those packs.
The LEDs in these lights appear to be a SMD type. They are small and darkened to the higher value resisitors. IMS I went up to a 4.7K one and decided it was too dark.
