Lighting Rolling Stock with DCC Track Power
Can a 3-LED string be powered by DCC track power through a bridge rectifier? Or is the rectifier not needed? It would require trucks with power pick ups.
RicZ
There is enough voltage for three 3.3V LEDs.
I don’t believe you need a bridge. Without it, the LEDs will only be forward biased half the time, so use half the resistor value.
Some people will worry about the reverse voltage across the LEDs. I believe a normal diode can be used to protect the LEDs.
You will need a bridge rectifier to convert the AC power to DC for the LED. It will work with out the bridge rectifier but the lights will flash very fast.
Slim
EDIT:
I decided to withdraw the circuit I had shown because CSX Robert pointed out that there was a risk of damage to the 5 volt capacitor should the LEDs fail. i.e. in other words, the cap might blow up.
Dave
The bridge rectifier will give you steady lighting on DCC when it’s combined with a capacitor. The circuit I use for the 12 v strip lighting segments and lots of examples can be found here: http://cs.trains.com/mrr/f/88/t/213765.aspx?page=2
Dave,
That circuit is very similar to the one I use. It should work for the 12 v strip lights, too, I’d think.
You really should use either the bridge rectifier or the single reverse voltage protection diode. LED’s are diodes, but they are not design to withstand much reverse voltage and by not protecting them from that you risk greatly shortening their lives.
What I don’t like about this circuit is it uses the voltage drop of the LED’s to limit the voltage to the super cap. What this means is if the LED’s all fail, or you have a bad connection and it comes loose, the cap will receive full track voltage (minus the diode drops through the rectifier), not good for a 5 volt super cap. Also, you’re not making the best use of the cap because it will never charge above the voltage drop of the LED’s, so you will get very little keep-alive capability. I would think you would get better results from a similar size regular cap charged to track voltage, even though the capacitance rating would be much smaller.
Yes, I prefer a belt and suspenders approach and would use a regulator circuit, or, even better, since there should be plenty of room inside a passenger car, use multiple supercaps like used in the stay-alives for decoders such that the cap combo can handle full track voltage and then you wouldn’t have to worry about it.
Yeah, that’s the main difference between the two circuits, besides my using the output to feed the strip light LED segments. I typically use a standard electrolytic cap that’s rated for 470 uF at 35v. Plenty of voltage overhead and the lights will stay on for a minute or more, depending on you resistor and how many LED segments.
Hi CSX Robert:
I’m no electronics expert but I do understand your point about the potential problem with the 5 volt cap. I just deleted the circuit from my post.
Dave
Ummm … I wouldn’t be so sure. The single resistor is factored to the voltage required by a single LED (in parallel, the voltage remains constant) which is well below the 5 volt rating of the super cap.
Three LEDs in series will require more voltage and hence a lower value resistor which will feed way more than the rated voltage to that 5 volt cap.
Be sure to shield yourself when you bench test it. [swg]
Mark.
Have you tried this circuit ? Dave is successfully using it and I have as well for probably 10 years or more. You say there will be very little keep alive capacity … that tells me you HAVEN’T actually tried it. My caboose lights stay on for well over one minute.
Mark.
Hi Mark:
I decided to err on the side of caution and withdraw the circuit at least for now. I hope you are not offended. I don’t want to be the source of potential problems. Maybe I’m being paranoid.
CSX Robert’s caution about using a 5 volt capacitor in a circuit that is being fed 12+ volts seems to make sense. If a higher voltage cap can be used then perhaps that’s the best way to go.
For now, I’m going to sit back and see what others, including you, have to say.
Regards,
Dave
FWIW, I had the same results with Mark’s circuit.
Dave
As simple as my circuit is (was), it is no different than any other circuit … all the components are configured to work properly with each other. Alter one component or delete one component, it either won’t work or it will destroy itself.
No different than if the coil of a speaker goes bad and shorts itself (the odds of which are about as good as an LED burning out), you’ll blow the audio amp on your sound decoder.
If you play those kind of odds as a deterent, you probably shouldn’t drive your car either as you might blow a tire and get into an accident ! [swg]
Mark.
Hi Mark:
I guess the real question is: Will the 5 volt capacitor blow up if either the resistor or the LEDs fail?
Thanks
Dave
Of course it will. No different than any other circuit if a component fails - something is going to give … I’ve seen two decoders literally catch on fire due to a component failure.
Mark.
Component failure seems less likely an issue than potentially shorting the 12+v voltage regulator feed to something bare in the circuit that should not see more than 5 v. An install in brass or other metal car has special potential for this sort of failure. Good install practices can limit it from happening, but between that and test probing things can still happen.
Assuming failure typically occurs inside a closed car, at least any failure shrapnel is contained[%-)]
I wouldn’t worry about that circuit if I had it. It works. But it’s the sort of thing that’s mostly needed because the super-caps can be squeezed into places you can’t put the big klutzy components like my 35v caps. You can stuff a lot inside a HOn3 bathroom, though, and the components I use are probably cheaper than super caps (or have they come down enough where that doesn’t matter?)
Found a copy of my circuit plan done as a crude graphic and some more handsome older stuff…
Here’s a Before shot of the BLI CZ dome-obs.
And After it was dimmed.
This is a typical install in a heavyweight sleeper.
Mike:
I found your diagram a few days ago, but thanks for posting it again.
A few questions if you will:
What’s the voltage on the capacitor?
How long do the lights stay on?
How many LEDs can you run off of the circuit?
Thanks
Dave
