Does anyone know how to replace the gears on a Lionel Standard Gauge Crane?
Here is a parts diagram. Which gear(s) need to be replaced?
Larry
The drum and worm gear to paise and lower the hook.
How did it turn out? What process did you use to get the gears out----I’ve got the same trouble and the trouble is the crane is a full EX to EX±–almost not a mark on it and no tarnish other than the couples. I did find out one thing about it—it’s top heavy with the mast raised even a little bit, it will roll off the track if going to fast into a curve ----and I’ve got 72 and 54 diaminter Std gauge curves.
I need a parts diagram. but the website is unreachable or no longer in existance! hpw can I get one for the # 219 crane car?
Thanks
Greenbergs Repair and Operating Manual has it.
Larry
I have the 6th edition of Greenbergs, but I can’t find the # 219 in it.
Do you have a page # for it?
Thanks,
George thill
Thanks!
Any other Info on replacing parts in this crane would be great.
George Thill
