Anyone happen to have a template to use when painting the Warbonnet paint scheme? I’d like something I could tape on and paint around. I do have the decals on hand but am having issues painting the shell using just tape to mask things off. If a cardboard template is available that can be taped on and painted around might help a bunch.
If you have access to a scanner that allows precise output scaling – scan the actual decal, and scale printed output to exactly the same size. Then cut the templates from copied sheets.
You can use frisket to make the actual ‘mask’ that seals to the shell.
Thanks, Woke_Hoagland but I’m completely lost at what you stated.
Can you maybe clarify a bit more.
I figured out, Woke! I appreciate your help! ![]()
