Lionel 56 replacement window struts
Anyone ever see or use replacement struts for a Lionel 56?
Also need a compete set of 4 of the white hand rails.
TIA.
The replacement struts are currently made by Joe Mania: http://www.jlmtrains.com/new_items.htm
I’ve used them. The results are good. Now folks have something else to check for when they are buying one of those small locos.
Last I knew, the handrails were readily available, but I have not tried to buy any in a long time.
I see them on George Tebolt’s list. I did not see them on Train Tender’s. Might not have looked in the right place.
Thanks for the info. I’ll order a set from him.
I picked up a running 56 for $69 from ebay that needs struts and one rear handrail, but I figure I’ll just get a set so they match.
Don’t forget the rivets. :slight_smile:
I did locate a set of 4 at East Coast Train Parts. Says they come with rivets. Will give a report when they arrive.
Just for the heck of it today, I went on ebay and put in search " Lionel window struts" and came up with an auction from “Trainz” that showed some red ones for 2 something each. I bought 4. I can paint them if needed. He still has more as the auction was relisted if anyone needs any.
