Hello,
My first post here!
When we set up our Polar Express train around the Christmas tree this year, the CW-80 transformer made buzzing noise and
Hello,
My first post here!
The fan sound from the CW-80 is normal.
Have you tried to run it in reverse? Check the switches and set reverse to “on”.
This set is getting old now, and it may be suffering from a lack of lubrication as it wasn’t great from the factory. This is the small motor version as well, I believe, so it may be time for a replacement motor. You can inspect the gears & lubrication status by removing the bottom plate & rollers from the loco.
Me and my brother do repairs for Nicholas Smith Trains in PA. in the last month we have gotton 4 PE’s locos that have stripped both the axle and the motor gear. He has a knack for working on the new stuff. In all cases both items were in stock at Lionel. and we had the owner order 6 of each motor and the geared wheelsets for repairs. Lack of chinese grease and aliginment seemed to be the issue.
Thaks Rob. The switch was indeed off. When I turned it on, and tried to run the engine in reverse and forward, it moves half an inch in each direction, but then stops. I will lubricate it and see how it goes. Thanks again for your helpful suggestion.
While lubing, I noticed that one of the rods has come out and it slightly bent. (See the picture) Any suggestions on how to put it back in?
Also, are there any videos on how to open this engine to grease the gears? Thanks again.
Success!!
I was able to remove the links assembly to straighten out the rods and put everything back together. Now the engine runs perfectly.
The only thing remaining is greasing the inside gears. Any recommendations on how to do it? It is just opening the screws on the bottom plate, or more is involved?
Thanks Rob. I did have a feeling that I have read that somewhere, just didn’t remember where. Any tips on greasing my brain? ![]()
On the Ploar Express, I lube all axles, bushings, & valve gear with Mobil 1, and I pack, & I mean pack, the worm and worm wheel with Lucas Red ‘N’ Tacky #2. I do the same with the 0-8-0 starter set engines as well, even before they hit the track.
