Lionel City 124 Station!!
Hello, How do you wire up a 124 lionelcity station?? I has lighting inside and outside. Has a hole on the side for wires to go into the building. I have no idea how to wire this up correctly. Any ideas? Thanks.
Hi! If you go to E-Bay, there is a station being sold. Says it is wired. Maybe, if you contacted the sellor, he would be able to assist you by looking at his. Item # 320702155826 Worth a try.
lionel2,
Have you gotten a satisfactory answer to your question via one source or another? If not, and no one else wants to take it on, I’ll try, I I don’t think it is very complicated. The three lights are all the “electrics” there are, and the station itself is metal, right? Advise.
Hello, yes, there are 3 lights, all with one wire going to one post inside the station. I figured out how to wire it up. There is a groung post and the power post. I attached the ground post wire to U on my Z transformer and the power post to D on my Z transformer. Then I applied some power, all 3 light lit up nicely. Guess it was not that hard to figure out, I am used to the posts being at the base not inside the building… Thanks anyways.
