Lionel Command Equipped loco won't move
I just received a Lionel H16-44 #6-28838. I ran it for about 20-min this afternoon with CAB-1, and everything ran great.
I wanted to run it again this evening, but the engine won’t move. Everything on the CAB-1 works except the throttle.
Here’s the resets I’ve tried:
  1. Replaced the CAB-1 batteries.
  2. Pulled out the crystals in the Powermaster, and CAB-1 and re-installed.
  3. Reset the Powermaster. AUX1,0
  4. The red light on the Powermaster flickers when the throttle is rotated.
  5. Reprogrammed the command reverse unit.
  6. Re-assigned new ID to the engine.
Suggestions are appreciated.
Thank you,
Kurt
Anyway you can disable command and see if the engine runs conventionally ?
Remove the shell and make sure the reciever board is firmly seated. Often times in shipping boards can work there way loose. I had the NH version at one time. I’m thinking it had the same symptons and was returned to Lionel. All the functions but no movement. I believe they replaced the driver board. They are great runners with a unique sound. Hopefully it will be a simple fix.
Nope. Won’t move in conventional mode either. The direction cycles with the direction lever on the ZW, headlights change sides, and the RS RPM increases with the increase in voltage.
I’ll open her up later, and see what I can find.
Thanks Dave,
Kurt
Upper board loose, I pushed it back to fully seat it.
No change.
Kurt
Kurt,
Have you tried to reset the engine? Also, is it Odessey equiped?
Do a factory reset. If it is answering to all commands except moving, could be a problem with the gears. Check to insure something is not in the gears or gears binding. I think it is a board problem and I hope the factory reset [means put the engine in program, address the engine and do an AUX1 and the proper code {in the owner’s manual} then kill power and switch to run].
Sorry, I lost track of this with our power out.
Yes, it does have Odyssey.
I did the factory reset. ENG #, Aux1, 8 for diesel, to no avail.
The wheels won’t move. I don’t remember if they would before I started the engine or not.
Either way, Trainz will have it Monday. They were quick in telling me to send it back when I opened a repair ticket.
Thanks,
Kurt
Kurt, hope they get it fixed asap. Trainz is a good place, I’ve bought a lot of stuff from them in the last couple of years.
Kurt,
Just an FYI that not all Diesels reset with #8. My SD9 resets with #5.
The SD9 I have is VERY sluggish with its Odessey system so I’m looking into changing from Odessey to ERR’s cruise. We’ll see as I haven’t opened the SD9 to check the boards. Looking forward to hearing your out come because my SD9 came from Trainz as well.
Kurt, did you go to PROGRAM and then reset? Then go back to RUN. Want to make sure you did not just do a rest. Brent, if that is new Odessey, can not believe it is sluggish. Newer verson does not have the jerk of the early kind and with Legacy, works great.
I did remember to switch to program, do a reset and switch back to run. I even tried re-numbering the ID, in program, and again tried a reset.
This Odessey runs great, very smooth, even at slow speeds! I am very impressed. Runs smoother than the Atlas GP15 at slow speeds.
Kurt
Chief,
I have three engines with Odessey:
6-28559 - Chessie GP-30 Legacy - OdesseyII (2007) RS5
6-28855 - Chessie GP-30 TMCC W/ Odessey (2005) RS4
6-28205 - Chessie SD-9 TMCC W/ Odessey (2003) RSII
The Legacy and 05 Odessey engines are smooth as silk, the 03 Odessey has some jerkiness to it. I’m going to try and work on it this weekend and see if I can get it to run better, if not it will be going back to Trainz. I have been in contact with them and we’ll see what happens. Very nice to do business with so far.
03 probably does have the “jerks”. Some of my earlier Lionel diesels with Odessey will almost stop and then recover, if you close the throttle fast. To make them smooth out you have to “feather” the throttle closed.
Chief - I don’t want to take over the thread, but mine won’t even move until the CAB-2 reads
‘17’ on the power meter. Then if I back it off to ‘10’ is runs but ‘jerks’, this has caused some lighter flatcars to derail.
I want to see what Trainz recommends before I do anything. I have read on ERR’s site where their Cruise Commander Odessey takes care of this, so if I can’t correct it with ‘natural’ parts, I’ll go that route. This isn’t the prettiest engine, but it gives me something else to run with the GP-30s (not MUed). I have contemplated buying the B&O GP-30, but think I’m going to hold off till I see what Lionel comes out with Legacy in the next couple years.
Brent, On my early model Odyssey engine I set the speed steps as hi as it would go and it helped a bunch with the lurch & jerks, ain’t perfect but lots better.
Hello my name is Tom and I work for Lionel trains in NY.
You say you reset the powermaster by hitting Aux1 and 0.
Well read page 17 of your powermaster manual it states that if you hit those keys you deactivate the track.
Please reprogram your powermaster to track 1 then press boost.
BMT, [#welcome]. Glad to have you around. Please step in and help us at anytime.
