Lionel O gauge Camelback 4-6-0 ten-wheeler
This locomotive was very difficult to keep running without constant throttle adjustments (TMCC).
I had to have an EOB unit installed in order to correct the above problem.
You better love the way it looks, because unless you are going to spend the extra cash to install the EOB, it is not much fun to operate.
Now if I could only correct the poor smoke unit output!
mine will not smoke period tried ALL the suggestions- zilch
