Will the drive wheels on the Lionel PRR 2-10-4 remain on 0-72 curves or will they lose contact and overhang the rails?
I just looked up the specs on Lionel’s PRR 2-10-4, and according to Lionel the minimum curve radius for that model is 0-72.
So, as long as you run it on a layout with 0-72 or larger curves you should be OK as far as tracking is concerned.
As an aside, I’ve found that sometimes you can run a locomotive on a curve radius tighter than the factory specs, but not always. It’s best to follow the specs.
HI Walt,
Please contact me at CTT regarding your excellent question.
Sincerely,
Roger Carp
Senior editor
Classic Toy Trains
262-796-8776 ext. 253
