Hi all. Does anyone know if they make a reproduction shell for the #60 trolley? If so, who sells them? Thanks!!
I am not aware of any.
I would check on E Bay. Sometimes there are some new old stock or a good used one available.
Do you think the holly jolly shell will work?
Seems to be a difference in the roof and the mounting would be in question. Otherwise the bodies do look similar.
On the reversing slide assy. Is the piece that makes the contacts supposed to be free of any grease?
When I service a piece with a reversing slide, such as a trolley or gang car, there is usually old, dried grease on the contacts and in the slide channel.
I clean out all the old grease, and paint a little Neolube on the physical contact area of the slide channel, and on the bottom of the slide.
I either leave the contacts clean, or put a little Neolube or Caig Moving Contact Lubricant on them.
Thank you sir.
Real quick question. I purchased the Holly Jolly shell and it has two led lights that are wired together. Can I just cut the red wire in half and run a lead to where the old light attaches and the same with the black and ground it to the frame? Again it’s a postwar #60 trolley with the new shell. Thanks.
Probably not. This is outside my expertise, so wait for a more definitive answer.
I think you will need a resistor and maybe a diode.
What is the common postwar bumpers used with these kind of cars? Also any help with above post would be greatly appreciated (led light hook up).
The common postwar bumper is the #260. Most were made of cast metal, but towards the very end of the postwar era they were made in plastic.
Less common is the #26 bumper.
In the modern era Lionel continued making the cast metal bumpers, I don’t know the stock number.
They may still make them.
Awesome. Thanks for the info.
