The phenolic piece under the motor that has the rollers attatched to it, has is that removed? Mine has a broken wire, and needs removal to resolder. Thanks
You should be able to move the E unit out of the way and resolder that wire without removing the roller plate. They generally break when you try to remove them anyway.
Roger
