The diesel MU case probably deserves an in-depth historical and technical treatment by someone in or with close connections to the industry. As an outside observer I still have more questions than answers after several decades of looking at it.
As well as the central issues of origins and the steps towards a common standard, some other aspects worthy of consideration are:
AAR involvement in what was originally probably a locomotive builder matter.
Air brake compatibility issues (resolved in principle with the arrival of the 26L brake, in particular with its universal version.)
Dynamic braking – EMD field loop vs. GE potential wire – somewhat resolved with dual systems in the mid-1950s, probably led by railroad initiatives more than the locomotive builders, then finally addressed by EMD’s adoption of potential wire control in 1961, with retrofits available for older units. Incidentally, this was never a problem in export markets, as EMD adopted potential wire control for export models from the start. There compatibility did not seem to have been the primary driver; rather the field loop control was found to be functionally less suitable for the export models.
The inclusion of supplementary functions, such as the humping control, which – in some export applications anyway, where low adhesive weight-to-power output ratios obtained - was also used to obtain finely graduated control during starting and initial acceleration.
The various engine governors, engine speed controls and load control systems that were/are used.
The “other” systems that were abandoned as the 8-notch system became the modal type and then the standard. These included the Baldwin pneumatic throttle, the Fairbanks-Morse pneumatic throttle (different to the Baldwin), and the Alco-GE three-solenoid, eight-speed control used on early switchers. It may also be noted that the GE 70-tonner, when MU equipped, had a four solenoid, seven-speed control. Some export derivatives of the 70-tonner had pneumatic seven-speed control, as I think did the US Gypsum 54-ton model.
The situations where the standard system was interfaced with control/MU systems that were somewhat different or quite different. Some examples:
The Milwaukee “Wylie Throttle” that allowed leading DC electrics to control trailing diesel-electrics. Good information on this is available.
The UP system that allowed leading GTELs to control trailing diesel-electrics. There seems to be no detailed information available as to how this was done.
The EMD system used on the FL9 that allowed 8-notch throttle handle control of the 28-step DC electric side. Reasonable information on this is available.
The GE 16-notch system. Only partial information seems to be available.
The SP diesel-hydraulic case. Finding the details is a work-in-progress, see: Krauss-Maffei Diesel Hydraulic Locomotives - Trains Magazine - Trains News Wire, Railroad News, Railroad Industry News, Web Cams, and Forms.
There were some export situations of this nature, as well. Two examples: circa 1965, EMD developed for New Zealand Railways a two-way interface between the AAR control and the English Electric 110-volt, 10-notch protocol. And in the early 1970s, for Queensland Railways Australia, Locotrol developed a one-way interface from AAR to the English Electric 110-volt, pneumatic protocol that allowed Locotrol receiver cars to be coupled to either Clyde-GM (AAR) or English Electric mid-train units.
Returning to AAR involvement, in the Trains 1968 December article, Pinkepank made a couple of observations. Firstly: “By far the most prevalent jumper is the 27-wire type first standardized by GM in the 1940’s. The 27-point receptacle succeeded the 17-point jumper originally used for FT units and the 16-point jumper still used by some roads for E units. It is now the Association of American Railroads recommended standard, but since locomotives are not interchange equipment, the AAR standard is not binding.”
And secondly: *“*The AAR has tried for the past 12 years to settle on a standard 27-point receptacle for adoption by all railroads, but the recommended standard has been changed so often that any road which attempted to keep up with it would have spent a fortune by now in electrician man-hours.”
From that we may deduce that the AAR had been involved at least since 1956, and that by 1968 it had standardized the on the type of jumper connection (27-pin), but not the pinout sequence thereof. Presumably that came later.
Apparently, the applicable AAR standard today is S-512, although I have not yet found a copy. But I have found APTA (American Public Transportation Association) RP-E-019-99, Recommended Practice for 27-Point Control and Communication Trainlines for Locomotives and Locomotive-Hauled Equipment. This was edited 2004 March 22; I do not know if it is the latest issue.
This shows four cases for the 27-point connector:
System for Diesel-Electric Locomotives (black colour-coded receptacle) [presumably the same as the AAR standard]
MU System for Cab Car Compatible to Diesel-Electric Locomotive (black colour-coded receptacle)
MU System for Electric Locomotives (white colour-coded receptacle)
MU System for Electric Locomotive Equipped for Diesel Logic Cab Car Control (black colour-coded receptacle)
The use of diesel logic for electric locomotive control effectively goes back to the FL9, but I imagine that it was much easier to do once suitable electronics became available, to the extent that it was more-or-less routine. The description of the available control systems for the EMD GM6C electric locomotive (Railway Age, 1975 May 12, p.10) suggest this: *“*Availability of five different types of throttle control, including the typical constant-horsepower diesel-electric type with eight throttle steps (this to facilitate m-u operation with diesels) ; constant-tractive effort controls which result in the throttle’s controlling the actual tractive effort regardless of speed: and various combinations of the diesel-electric type and the constant-tractive-effort type, whatever best suits the railroad’s train-handling. ”
Cheers,
