In all my years of railfanning, I have never seen an engine blow a piston, WOW it was somthing to see. Of cuurse that engie is shot since the piston blew right threw the block. Gonna cost UP a pretty penny for a new engine. They can always use the good parts out of the old engine and replace the block and bad piston as well. Does anyone know which option UP would normally take?
[color=blue]Diesel locomotives do not use cast blocks like the automotive engines we are familiar with. Diesel locomotive blocks are welded up affairs and, in the scheme of things, are easily repaired by cutting out the damaged section and welding in a replacement. The Cylinder/Piston/Cylinder head assembly is referred to as a ‘Power Assembly’ and are easily replaced. While an engine blow is is not an everyday occurrence, they are not that uncommon, either. After a several day trip to the shop, the engine will be hauling freight again as if nothing had happened.[/color]
“Piston blow”? Looks more like a crankcase explosion to me. It could be initiated by a piston failure. How would any of you know that the piston went through the block? Certainly not visible here. And no, not all locomotive engines use weldments for engines. And yes this crew was negligent in “oh wowing” instead of making any effort to save their equipment.
A power assembly is a rod, piston, cylinder (called a liner), and cylinder head complete with valves, in one unit. It bolts down onto the crankcase. On EMD 2-stroke engines, the cylinder head is bolted onto the cylinder liner so can be itself replaced if needed. I believe the GE FDL power assemblies are a little more integrated. The EMD 2-stroke crankcase is fabricated steel and can be welded, as needed. I’m not sure about how repairs are done to the cast iron GE blocks, or the EMD 265 blocks.
GE EVO engines while having a basic cast frame for it’s block assembly, has large ‘inspection ports’ that allow access to the con rods for their removal, without having to remove the entire engine from the locomotive.
Looks like it tossed a rod , the block is scrap if the rod hit the upper portion of the crankcase , if there is damage to the cam line the block cannot be repaired. If it only damaged the oil pan the block can be metal stiched, either way the engine has some serious damage.
Even with high speed on my Imac all I get on youtube is audio. Do you have any stills of it? Can you see a piston? I tore apart a Ford/IH 6.9 diesel that had destroyed one piston. Took the head off and one cylinder only had a rod in it, no piston. Piston was about 50 pieces down in the oil pan.
