Hello All,
As a married man, I am often wrong.
As much as “She Who Must Be Obeyed” disagrees- -I do admit it!
In my previous post, I stated that in the “Long Address” (Extended Address) mode all 4-digits need to be used, and that leading zeroes are not recognized.
After doing some address programming experimentation I realized…
I am wrong!
To clarify- -I am using the NCE DCC system; Wireless 5 Amp Power Pro, with mostly Digitrax decoders: DH126 and DH166 series, a few TCS, and OEM Bachmann.
I do use JMRI Decoder Pro powering a separate programming track through a Digitrax PR3 driven from a Mac.
For this “test” I used a Bachmann GP38-2 (diesel) with an OEM PCB decoder and the “Programming On The Main” function from the DCC system.
I also removed all locomotives on my pike before programming, to avoid any possible batch programming errors.
On my roster, this unit is assigned the 4-digit address 3524.
With the NCE system the prompts are as follows to change an existing address:
- Press "PROG/ESC
- PRG LOCO ON MAIN (Press Enter)
- PROG LOCO: 3524 (Press Enter)
- LOCO: 3524 1=ADR 2=CV 3=CFG (Press 1)
- SET ADDR 1=LONG 2=SHORT (Press 1)
- SET ADDR LONG ADDR: (Key In) 2-8-8 (Press Enter)
To confirm the new address I cycled through the direction with the lights (F0) enabled to confirm the new address and correct direction; F=Forward, R=Reverse.
When I ramped up the throttle (128 steps enabled) the loco responded.
Next, I stopped the locomotive, and called up the address through the keypad:
- SELECT LOCO (Key In) 2-8-8 (Press Enter)
- Went through the standing confirmation process as above
- Throttled up and away she went!
There are a couple of resources yo
