Hello.
I have 3 Walthers Proto locos and a Digtrax DT602 controller. Everything has worked great until the other day. 1 loco will not move. I’ve trouble shooted the problem and found that all the sound and lights work. When I throttle up with sound on, it sounds normal like it should but no movement. I use identification number 288 with ID4 enabled. When I use a lower number like 0004 (the factory default is 0003) the loco works perfect. I just will not move if I set the identification number at 128 or higher. I’ve factory the loco and the problem continues. The other locos still work fine.
I’m confused and at a loss. I’m pretty new to DCC and any advice would be greatly appreciated. Thanks in advance.
