Just purchased two new Kato C44-9W SP’s with factory installed Loksound decoders. I’m somewhat new to DCC and this one has me completely stumped. Here’s the problem I’m hoping some of you veterans can help me with.
I have two locos on the track. #1 and #2. Track is powered. I hit F8 to start the prime mover sound on unit #1. Then on my NCE controller, I switch to unit #2. I hit F8 to start that prime mover sound. Both do start up sequence and settle into a nice ide.
Now comes the issue. When I use the controller to switch back to unit #1, the prime mover goes immediately into shut down mode and starts the shut down sequence. Not just turns off. But the shut down sequence…almost like I had hit F8 again.
This happens if I have another loco on the track or not. I can have one loco on the track, switch loco numbers on my controller then come back to that loco and it shuts down.
I have no idea why or what the heck is going on. Does anyone have ANY ideas I could try?
I have the Loksound programmer and can adjust anything easily as far as CV’s but can’t figure out what needs to change here. HELP!
Does the throttle remember functions that were turned on when you access a previous engine ?
For example - you access engine 1 and turn on F8. You then go to engine 2 and turn on F8. When you return to engine 1, is F8 still turned on ?
I know some systems will remember function setting when you re-access the engine, while others will have all functions set to off when you go back to them. If that’s the case, when you go back to an engine and all the functions are re-set to off, the decoder sees that F8 is off and goes into shut down sequence.
If that is the case with your NCE system, I’m not sure if there is a setting you can change for it to “remember” previously set function positions or not. This is not a problem with the decoder per se.
Thanks for the thought Mark. I have hit up NCE to see if there is some sort of setting there.
I saw another guy post something similar…that his prime mover was shutting down but he was still getting the “ticking” noise of the bleeder valve or something of the GE loco’s. Mine is the same issue. Still get that cool ticking noise. Just motor sounds shut off.
Hopefully NCE can come back with something for an answer. Someone mentioned changing CV 124 to a 6 but I can’t find anything that confirms that. And I love the way the loco acts, reacts and runs with the sound as is. So I’m changing nothing until I have solid proof I won’t be jacking anything up!
I had the very same issue just last night. After running a consisted pair of Intermountain F-7s with Loksound Selects I decided to simply program the trailing engine to the same number as the lead engine.
The problem was, F8 would kill one while firing up the other, didn’t matter if I had the wheels off the rails when I turned on or off F8, it would just toggle.
I have a Digitrax DCS 200. I have been running probably two-dozen different Loksound Select engines over the past two years or so and last night was the first time I’ve ever encountered this. I have several A-B-B-A sets all programmed to the lead engine number and never had any issues.
I haven’t done it yet but what I’ll do is reprogram the address back to the original road number, hit F8 once on that engine, then program back to the MU paired address numbers. That should clear things up.
Ed, sounds like F8 is functioning opposite on one of the engines. (?) When you place the engine on the rails, does it start up by itself, or is it silent until you turn F8 on to start it ? Does the second engine work the same way ?
The thing that I found unusual was the decoders “remembering” the F8 command.
In the past F8 would toggle sound on or off unrelated to F8 being on or off. Like Randy mentions about MTH Protosound. All I would simply do is lift one engine’s wheels off the rails and toggle F8 and everything would be back in synch.
So as I mentioned, last night I decided to make some consist changes and took a pair of Fs that had been MUed by universal consisting. I broke that up then readdressed the trailing unit and set the NDOT to reverse.
After a few minutes of running I realized one unit was silent. Simple fix, I thought. Lift it off the rails, hit F8 once and place it back on the rails… no go. Now the other unit is silent. (I realize the OP’s problem is slightly different since he has two different addresses) but the odd thing is, since he posted his problem, I was surprised that I was experiencing the (almost) same thing. F8 toggles the prime mover. I don’t know why it is not programmed so that F8 on = sound on/F8 off = sound off?
Normally, when I power-up the rails the prime mover on all my Loksound engines comes on. If I want to mute them I have to select their address and either turn F8 ON or OFF depending on the current status of F8. If I briefly turn off the track power and back on again, the standing engines will go back to idle (sound on) then I have to go through the muting sequence again, turning F8 on or off as needed.
I’m sure there are customizable CVs to choose (by default BLI engines stay quiet until the address is called up) but I just have not found the time to sit down and do all the tweaking of CVs that I’d like to do (speed matching, for one!) I have the Lokprogrammer, too, but so far I’m only scratching the surface of its use.
Just out of curiosity, when you switch from one unit to the other are you “recalling” the second unit from the recall stack or are you “selecting loco” and entering the unit number again?
From reading the Loksound Yahoo Group forum it is my understanding that aftermarket Loksound decoders (Select style) come with the default set such that the motor does not start on power up, but factory installed decoders are set to start up on power up because “that was what was specified” but the loco maker.
There is a CV that can be changed to change this, but I don’t know which one at this particular moment.
I am not using the recall feature. I know that is an option but I don’t overly care for it much. I don’t want to have to log all 18 locos on the layout into that. Especially since it only holds 6. Not that I run that many. But I want to be able to point to a loco, put in it’s number and run it. And not have the other one shut off and go into sleep mode. I understand the recall feature and that it would work without much issue, but like I said. It’s not my favorite.
If I recall correctly, these were two installs that I did on a pair of BLI Blueline F-7s that I got tired of messing around with the dual decoder thing.
I’ll report back when I get a chance to play with the CVs you provided. If nothing else, I can always do a factory reset and use the Lokprogrammer to customize both engines to the same settings.
Sorry forgot to reply. I am selecting them as new. I have the recall option that works ok, I just don’t care for it. I don’t want to be limited to 6 locos.
The reason I asked was that I was wondering if the same problem would occur if you recalled the loco instead of entering it as a new unit. If you can try that, I’d appreciate knowing what happens.
OK, so I tried things tonight. NCE had me try to change in the master directory something about 'Function Refresh Enable." Did that and still no dice.
To answer your question though as much as I hate it, things work perfectly in recall mode. I don’t understand what the difference is with recall or just typing in and selecting a loco. That’s just my inexperience talking there though.
So still at square one. Shuts down when I select but works when I recall.
Sounds like this is an NCE ‘feature’ where if you select a loco from scratch, it sets all functions to off, but if you use recall, it sets them to however they were previously. Try it with the headlight and see if the headlight goes off when you reselect the loco, but stays on if you pull it back from the recall stack.
Digitrax may do the same thing, except that if you already have F8 turned on, the loco will never be purged from the command station’s slot table, so in effect it always remembers the function state. I suppose I could test this by using JMRI to purge the slot used by the Loksound loco and then select it on the throttle and see if it shuts down. The problem with F4 and the MTH locos isn;t quite the same - the problem is MTH set it up as a toggle, not a function on = loco started up, function off = loco shut down like Loksound, so there I have to lift the one that’s ‘running’ off the rails, send and F4 to start up the one that went silent, and then put the running one back on the track. If they were more like Loksound, or at least had a setting to power back up in previous state, there actually wouldn;t be a problem with them.
Mark-
Yeah, I threw out multiple lines hoping someone would come up with the answer. They are getting into it pretty good over there.
Randy-
Unfortunately it only does it with the prime mover sound. I can run lights, ditch even get the loco crawling…it remembers everything but the fact that prime mover. Drives me mental! LOL!
I had a similar experience with a set of consisted locos. Select the first loco and start the motor (F8) and turn on the headlight, select the second loco and turn on the motor and turn on the headlight. Run set around.
Then I parked the consisted units and selected a different loco. Ran that around. Then re-selected the consisted units. The second I pressed enter after making the selection the motor stopped and had to be restarted. I believe that only one of the consisted unit’s motors stopped.
Note that I was using a throttle that had a rheostat, not an encoder (one of the dummy throttles). I think with an encoder throttle this didn’t happen.
Matt from Loksound was there to watch all this happen. I think it has something to do with the fact that the encoders don’t really have an off position, but just remember where they were the last time they were used, where as the rheostat throttle has to be “off” when you select the loco so all the functions revert to where they were before the F8 was pressed. However, as you noted, this all just seems to affect the functions, not the motor drive.
