Hello There, I am modelling a British layout and need some buildings that are similar to buildings in London, does anyone know of a manufacturer of such buildings. Regards
London is huge, with many. many styles. Even the City has a ton of different styles. Could you provide some prototype examples, maybe from Google Earth? Streetview?
Also, HO scale, N scale or OO scale (or other). Obviously OO scale provides all the british building styles you could need…HO scale or N scale, maybe you could modify German style buildings, or some of the older American style buildings
More of the regent style, similar to what one sees around knightsbridge.
Found a couple of paper sites that may help:
https://web182.secure-secure.co.uk/modelrailwaybuildings.com/index.php
General UK stuff but quite good.
Cheers,
Glenn
Definitely Scalescenes if you don’t mind card stock construction. When you scale the pages for printing, the horizontal bar at the bottom of a page is 63mm long for HO.
I have a number of the Superquick buildings. These are more of a mid-sized town than city, but they’re very nice and highly detailed. They are, however, cardstock, and some people object to that.
I take it that you are modelling UK outline in 00 not H0? (As in 4mm = 1’ not 3.5mm = 1’) This means that you will need to get 00 buildings from UK suppliers. Best source to discover what is available (other than the net) is “Railway Modeller”. This is the “Exchange and Mart” for all UK Railway model stuff.
What railways there were in the Knightsbridge area were underground… not just the London Underground (tube) system but the main lines as well… mostly freight… delivering direct to private sidings under the stores. Could make a fascinating subject for a switching layout on a shelf.
Knightsbridge and anywhere else in the West End that was posh didn’t let the smelly, noisy new fangled railways in anywhere near their smart frontages.
What you do find is the railways squeezing in between backs… frequently low cost (small) housing or industrial - some of which would be later infill.
To get an idea look at films like “The Ladykillers” and other Ealing productions. If you can look at British Transport Films’ stuff (Now held by the British Film Library I think… some of it is on line).
In London you would be modelling only one or two companies… depending very much on date…
Knightsbridge would be GWR or BR/WR. Both had 0-6-0PT with condensing gear for running freight in the tunnels. The GWR also had some joint owed stock with the Metropolitan… ran out towards Ealing IIRC.
Southern (1926 onwards) would mostly be 3rd rail electric for passenger. You can get models.
Crossrail is now being built - underground mostly…
Let me know more of what you want to do…
What date???
[:P]
I am modelling part of my layout on the Knightsbridge Tube Station and it is in the 1930s-1950s, no exact date. I also am doing Oxford Circus so if you know any building models that are similar to those do tell.
