If i wire the tranfer table with the Reverse Loop Module because it is isolated,i believe it will do the looping without extra wiring.Or not?
Also if i use the same module for another Loop or wye with the precaution not to coexist 2 trains at once in both loop,will it work?
If those two tracks leading off to the rest of the layout form two of the legs of a wye, with the transfer table as the tail of the wye, then yes, you can wire the table up through an auto-reverser and that will handle everything.
Really nice looking work on that transfer table.
Even though you’re right about being able to use the same Reverser for two different loops or wyes, as long as you’re never operating across both loops/wyes at the same time, I would still advise against it. Sooner or later, you will get into that situation, regardless of your operating rules. Might as well do it right the first time.
