Main Track vs. Program Track
I’m new to all of this. I’m hooking up an MRC Prodigy Advance 2 for DCC. Is a “Program Track” just a small piece of track that is completely unattached to the main track and used solely to program the loco? Thanks in advance for any help.
Yes it can be. Some people put the program track in a yard. Mine is on the work bench.
Pete
Yes. My Bachmann instructions say to add resistors to the programming track to limit the possibility of decoder damage when programming a new decoder for the first time. (in case it’s wired wrong) I don’t know if MRC recommends that or not. You’d have to refer to your manual.
Pardon a question from a DCC ignoramus.
Is there any reason that a piece of layout trackage, say the track leading from the yard lead to the diesel shop or turntable, can’t be completely isolated, then wired through a DPDT switch. Toggle down, program the locomotive. Toggle up, connect to the regular DCC bus and be off to the departure track to pick up an outbound train.
Comments, please.
The idea of a programming track is that it is meant to make any booboos you may inadvertently make constrained to the one decoder getting the signal. All other decoders in locos around the layout will be spared the miscue and won’t be affected. Saves time, and in the odd case, some money. Certainly a fair bit of aggravation.
What I did, because it was the closest track to me when operating my layout, is to make my turntable approach track gapped at each end and make it isolatable via an SPDT switch. When I get a new loco, I place it on the rails between the gaps (they’re about 24" apart), throw the toggle, and then power up my DCC system. The layout remains silent while I deal with the various CV’s in the new decoder.
As loathar has suggested, you will need a resistor or a booster with some systems because some decoders won’t accept the weak signal when using the programming circuit.
I have a dead end spur siding setup this way for a programming track.
My program track is a siding.But why when I try to program a new loco using the four digit numbers of the loco,it will not move but I try 0003 it runs?
No reason at all. On our club layout, the programming track is a run-through siding with an isolated section wired through a toggle switch just as you describe, and on my home layout it is a dead-end siding wired through a toggle.
Some systems use full power to program and current limiting resistors will prevent damage to decoders that may have installation problems. These are installed in series in the track leads.
If MRC uses a current limited program output, the extra resistors aren’t needed.
Adding a 1k ohm resistor is a trick to increase programming current for some sound decoders. It’s usually needed on some current limited programming tracks. This resistor is connected across the rails.
Your decoder has understood your request for it to respond to a new address, but it needs you to say, “Yes, you may,” to its question, “Froggy, may I?” What you must do, after you input the 4 digit address, is go into Ops Mode and change the value in CV29 to either 34 (if you don’t want the decoder to recognize DC signal if it gets it sometimes), or 38 if you want it to recognize when it is on a DC layout in addition to DCC. Most of us use 34.
I’ve just got an isolated piece of track next to my TT. I have found that on some locos with sound, particularly BLI, you might need to add a Program Track Booster - I use PowerPax Programming Track Booster from DCC Specialities. It costs about $50 but sure solves a lot of programming problems.
Make it a center off DPDT switch. If you hook up a programming track booster you don’t want to short the booster to the operating track.
That’s basically what I do. I actually prefer having it on the mainline so I don’t have to keep lifting the engine back and forth to make programming changes.
As far as the resistors, you shouldn’t really need that IF you remember to put the engine onto the programming track first, not subject it to ‘mainline’ power right away. Try to call up a CV like the two-digit address. If it comes up “03” then you don’t have any shorts and you can program and run the engine. If it doesn’t read, there’s a problem and you need to go back to the workbench. The programming track power is less than the regular track, so a short won’t burn out the decoder on the programming track.
I also use the MRC Prodigy Advanced. I do keep a seperate programming track just because I know that I’ll forget to throw the toggle switch someday. Some of the BLI’s seem to want programming on the main and I’ve done that too but removed every other piece of decodered equipment to do it. That would be a good excuse for an isolated by toggle piece of track. Programming on the main without the headache. J.R.
Selector,can you explain that to me about CV’s and froggy may I? I qm also new and it does run on 0003 and I get the head lights but casn’t get the speed steps any faster.
I have a blocked layout (it was originally wired for DC) with blocks all wired to their own DPDT switches. With this setup I can turn the track in any block into a programming track with the flip of a switch.
froggy - if your loco does not respond to a new address and you’re using a PA and a programming track its likely you need a Program Track booster - the condition you describe is exactly what happens when a new loco does not accept a new address. (All DCC locos have a default address of 03 when you first get them.) PA’s are bad for this especially if you have a sound equipped loco. You can either buy a program track booster (which is what I did) or program on the main track. If you program on the main track make sure you remove any other locos first. Also, on a PA you need to select the speed step then hit enter on your handheld before you run the loco.
At the end of the PA instruction manual it says you will probably need a program track booster!!
In addition to the comments made by all responders, particularly the comment above this one, decoders will take your input to change to an extended address, but they won’t act on it until you actually say to them, “Okay, now enable this new address.” (I was using the analogy of the childhood game “Mother May I”, which you may not know…sorry if that is the case.) So, you would change the address, dial it in, and nothing would happen to the loco as if it didn’t accept the new address. Well, it has accepted it, but you have to then tell the decoder it’s okay to actually respond to the new address. So that is where changing CV29 comes into play…and then only for the long or extended addresses. For addresses less than the number 128, those don’t need this procedure because they are considered “short” addresses.
Yes, you can do that, but you need a section of track between the programming track and the rest of the layout that can be disconnected from the system. Otherwise, if your engine goes across the boundary and connects to the live trackage, it will not be good. It should also be longer than your longest locomotive.
To do this, you need a 4PDT (four pole double throw) switch. One pair of poles controls the programming track’s connections, the other pair will energize or de-energize the lead-in track(s). Cheaper and safer than using two switches.
http://www.dccwiki.com/Programming_track See for more info.
Or, you could use a simple SPDT as I did. Just have two sets of wires coming together at the input terminals. The other end of one pair comes from the DCC base unit, and the other end terminate at the rails of the programming section of track. So, power leaves the base unit and travels to the one pair of terminals that also have one end of the feeders to the programming track section wrapped around them. The layout-proper gets power only from the other two terminals when the toggle is thrown for that to happen. When you want to programme an engine, run it onto/place it on the programming section, throw the toggle, and you layout goes silent. Power is still going to the programming section because it is straight through from the input terminals on the switch. That’s how I do it.
-Crandell
