I am want to make my own railroad short line and I want to make decals for the loco and rolling stock I plan to use.
I have looked into Inkjet matte polyester decal paper or INKJET Waterproof PERMANENT Adhesive CONTOURING Decal Vinyl paper. Which of these would be good for this project? Any tips or advise before I get started on this project?
I normaly us the testers brand decal paper on my epson printer. Lately as i am out of ink i used my dads cannon injet i and i think it did a better job on the decals.
I’ve been making my own decals since I got my first Inkjet Printer in early 90s. The quality of the decal paper is very important. I’ve always had good luck using Testors Decal paper. I normally go to hobby decal type sites for my decal paper, when I find a good source I stick with them unless I get a bad batch. Some of the water slide decal paper out there doesn’t do well so I wouldn’t advise buying in bulk until you know the quality of the paper.
Testors start up kit would be a good start, it comes with pretty good instructions, several sheets of decal paper as well as Decal Bonder.
The price of Laser Printers as dropped over the years and they will do a much better job making decals. I have all three types of printers, Inkjet (HP), Laser (Canon) and a Dye Sublimation printer (Alps). All three will print good decals, Laser has better quality than Inkjet and a Dye Sublimation printer will print white, silver and gold leaf.
I’ve only had one bad batch of Laser Decal printing paper and it was given to me from a friend that ask me to print out some of his decals. I don’t have any idea what the brand was. Actually the decals printed out very good, he had problems getting them to slide off the decal backing.
Decal Paper has both Laser and Inkjet, I haven tried their Inkjet Paper . . . . Bel Decal Inkjet paper has alway worked good for me. If it isn’t broke don’t fix it.
You want Waterslide Decals paper. Make sure you choose the correct type for your printer. Laser is the best if you have a laser printer. If you only have an inkjet printer you will have to spray a sealer on them or the ink will run when you put them into the water.
I failed to say that Inkjet printed decals do require a sealer to prevent the ink from running or bleeding. Lone Wolf is correct about that.
I use Testors Decal Binder 9200 for all decals that need shrinking ability over rivets and small details. For non detailed areas Testors DullCote or Gloss works very good, flat clear RustOleum or Krylon also works good for non detailed areas. Decals sealed with anything other than a decal bonder will not pull up tight around details with Microsol or Solvaset. Very important for perfect decals!
Mel
I’ve got an easy little project to do someday, and the biggest impediment is that it needs custom decals. On the plus side, the model is white; so the white ink problem ain’t. A problem, that is.
Since I’ve got a color laser printer, I’m gonna try some color decals. Hey, if they don’t work, I can always go back to black.
