Making stencils
Hi. Does anyone have a good and fairly easy way to make HO scale stencils for road markings (ie: RR crossing, one way, stop, etc?). I will be spray painting the stencil on to the roads. Thanks.
JRP
I use 3M Delicate Surface Painters Tape 2080, works good for making weird shapes on my locomotives. Should work OK for making road stencils.
I made the template on my CAD then used the template to cut out the masking tape.
For straight lines on roads I just use the masking tape.
Mel
My Model Railroad
Bakersfield, California
I made a stencil using a fairly thin but relatively stiff piece of cardstock. It had a metallic coating of some sort on one side, so I applied some Letraset rub-on lettering to create the words for sign, then used a new #11 blade in my X-Acto to cut out the letters.
The signs were for some fences at a number of coal and ice dealerships, so I had the fences all built and ready to be installed once the signs were painted.
I used my airbrush to apply the paint (Floquil), then used some lacquer thinner to clean the overspray off the stencil.
Here’s the results…
Since I still plan to add a couple more dealerships on the partial upper level of my layout, I’ll have to figure out where I stored the stencil…[banghead]
EDIT: Just for clarity’s sake, the lettering on the fences was done using the homemade stencil, while the lettering on the signs attached to the structures are all printed. My brother does the layout work, on his computer, to match the specifications that I request, then sends the data to a printer whom they use regularly, for a home-based business.
My brother has also done the artwork for all of the lettering for my freelanced railroads, including three orders of dry transfer lettering from C-D-S, (50 sheets each) and two orders of custom decals from Rail Graphics.
He also did a large multi-piece sign for me, on his printer, with a black background on clear decal paper, with the lettering left clear.
Applied to a painted-on white background, it looks like this…
In a box marked ''Templates"?
PS: doctorwayne, it’s 0422 here and I can’t sleep, it is such a joy to look at your pictures.
It’s really great to look at everybody’s pictures of their layouts and such that they post here.
Do you know anyone with a Cricut machine? That would be a great way to make accurate stencils in a hurry.
I still have a set of Greg Komar dry transfers that had highway markings in the set including the RXR street markings. I’ll see if I can find them. Unfortunately, Komar closed up shop in 2013.
Good Luck, Ed
Beautiful work Wayne. Thanks for sharing. I should add that I can’t use decals because I’m using 2mm foam for my roads and I don’t think that decals will adhere to it. So, the necessity of having stencils. I hope mine come out looking as good as yours. JRP
Yeah…I should be so organised. [:-^]
For a second-or-so, you caught me off guard there…I was worried that the pictures were interfering with your sleep.
Thanks for your kind words. I’ll have to see if I can come up with something that’s more serene.
Perhaps this will be a little more conducive for a good night’s-sleep…a pastoral scene…
…and I’ll say, without hestitation, that I’ve never heard a peep out of any of them, let alone a “moo”. Sleep well.
Mmmmmmm . Cow pies.
Now where in the fridge did I put my can of GernWhip?
