Hi everyone.
I am a geographer and I love maps, aerial photographs and satellite images. I would like to know if there is something I can search for on maps in relation to railroads?
Thanks for your help!
Hi everyone.
Any good topographical maps should have railroads indicated, just as they’d indicate any geographic features. I haven’t kept up with where you get them, but it shouldn’t be too hard for you to find out.
One source for maps pertaining to railroads, and railroads only, is "Steam Powered Video Publications. They have a series of map books pertaining to North American, both the US and Canada.
www.spv.co.uk Look under “Railroad Atlases”
SPV atlases are also available from White River Productions.
Thanks for the info.
I was searching more for what can I do with maps in relation to railroads. Are there interesting informations I could search? New spots to check trains or freight yards?
I don’t really know because I am a complete newbie into this
I use Google satelite maps. For an example try Albuquerque to Barstow, CA for the BNSF line that, in many places, parallells I-40. There are many trains and different terrain from mountains to desert. You will find railroad yards as well in Barstow, Needles, Winslow , gallup and Belen, NM.
And when looking at maps, what are you searching for exactly? I am pretty good at maps and satellite images so I could search for more harder things.
You can see trains operating including Amtrak #'s 3 and 4.
Try historicaerials.com. They have vintage aerial photos, as well as vintage topo maps. Some areas have better coverage than others, but there is still a wealth of information available.
On a topographic map, railroads tend to be indicated by thin lines with regularly spaced cross-lines, kind of like track ties, but not as dense. Yards will be indicated by more of the same. Also, if you know how to read a topo map, look in the flatlands, for lack of a better term. Railroads typically follow the “path of least resistance,” that is, they try to stay away from steep hills or other rugged country whereever possible. A lot follow along river banks.
I found a Canadian source for topo maps for you, and in fact, when you click on the website look at the 1:50,000 scale map, and right in the middle where Carleton University is there’s a rail line like I described. See if you can spot it.
A few things I should add. Conventional road maps, either fold-up types (assuming they even make them anymore!) or road atlases may or may not show rail lines. ADC atlases seem to most of the time, and I think National Geographic atlases may do so as well. If there’s railroads shown the map legend (usually in the first few pages) will indicate what to look for.
I should also add that those railroad atlases from SPV won’t show you where the roads are, just railroads only.
A Google map will show you rail lines (and everything else) but you have to zoom in to see it and know what you’re looking for. Take this Google map of a town in New Jersey I’m familiar with.
https://www.google.com/maps/@40.9816175,-74.148343,13z
Look for “Ridgewood” in the center of the map, and the blue mark that has an image of what looks like the
https://search.mytopo.com/searchplaces
I find this website sends me down rabbit holes for hours at a time. I usually use it to find where railroads used to be in my part of the world.
This might be a good place to start your railroad map research:
https://trn.trains.com/railroads/railroad-maps
The material posted here was originally published by TRAINS in their old “Map of the Month” column. TRAINS has compiled these past map articles into two special Railroad Map publications that you can find in their on-line store. I would heartily recommend both volumes.
Most of the Class I railroads have detailed PDF format system maps posted on their websites. These can be very useful in learning about the railroad lines close to where you live. They are also a good starting point/guide to looking at specific rail locations using tools such as Google Earth. Here are a few examples:
Canadian Pacific: https://www.cpr.ca/en/choose-rail-site/Documents/cp-network-map-2020.pdf
Norfolk Southern: http://www.nscorp.com/content/dam/nscorp/maps/2016-system-map-print.pdf
One of my favorite pastimes is looking thru railroad employee timetables and then locating all of the stations, yards, control points, passing sidings, etc. using Google Earth.
I find google maps thin blue lines are very hard to pick out. Do you you know any method to improve their contrast or visibility?
Really, the Google map RRs are way too hard to see. You have to enlarge to the point that you lose your overall bearings.
The Garmin GPS built into our Honda shows RRs really well.
Waze has started alerting for railroad crossings. Makes it easy to see where they are at.
I use Google Earth and RRs start showing up at an eye altitude (listed in the lower right corner) of around 130 miles. That allows me to see roughly 1/2 of the state of Iowa on my laptop screen. The lines are black (not blue). Granted they are thin at that altitude, but they get thicker as I zoom closer to the ground, but they are quite evident to me in my bifocals (that I have to remove to play a game on my smartaleckphone).
The lines tend to be the thickest at an altitude of around 75 miles which allows me to see at least 6 counties centered around Cedar Rapids, Iowa. I can see the Union Pacific main that crosses the state, Canadian National from Cedar Rapids, to the north toward Manchester, Iowa Northern from Cedar Rapids north toward Waterloo, CRANDIC from Cedar Rapids to Iowa City and to the connection with Iowa Interstate near Amana and the Iowa Interstate line that spans the state. Granted, at that level only 2 cities are labeled, but there is no loss of orientation given the labeled major highways. One step closer in zoom level (approx 60 Miles) and 18 city names show up, if I do lose orientation.
Unfortunately no. Obviously Google doesn’t give too much importance to rail lines.
I find this interesting to browse:
https://fragis.fra.dot.gov/gisfrasafety/
Also, in addition to system maps at individual RR websites, BNSF had a full US map PDF.
NY DOT has a pretty comprehensive map that shows not only active lines, but historical lines as well. It’s not real detailed, but it’s certainly something to get someone started in their search for more information.
I’d imagine other states have something similar.
For topo maps, the best place is the USGS site for historic maps (they show current maps also, but the newer maps within the last ten years seem to show less railroad detail). The 1:24000 scale maps show the most detail.
Seems to be hung-up on macro mapping, orthophotos and GIS (frequently inaccurate crap unless it’s survey grade material* - way too many liberties taken with how railroads work.)
Try looking at valuation maps and ICC General Order #1 of 1914. Then take a peak at the other 25 general orders and how it all fits together as cadastre.
*ArcView/ArcGIS/ESRI made themselves look like total idiots over a demo program that involved the former ATSF branch at Redlands, CA about ten years ago. (Garbage in = Garbage Out, railroaders saw that and gagged[+o(])
State of the Art Railroad GIS? - Hands down belongs to Union Pacific with their Do-Maps set-up and the PMV data capture vehicles. (CSX adopted it, BNSF went down the wrong rabbit-hole (Chase Flymap), NS is a mixed bag and KCS and the Canadians bring up the rear.)
This used to be one of my go-to sites, especially because you could flip back-and-forth between map and satellite view. Unfortunatly recently they redid the site. Now a moving pop-up box obscures part of the screen, trying to get you to buy their services. I guess that free things in the internet will be a passing phase.
