Marc model 501 installing to atlas 220 controller. Need help on where the wires go from transformer to controller
Need to this hobby and have some old equipment need help on getting the throttlepack to work with controller
First, welcome to the forums. You will find a lot of help here. But you will help the helpers if you include sufficient and accurate information in your queries.
I believe you are referring to the MRC 501 powerpack, not a “Marc 501.” If you are trying to wire a rerse section/loop or a turntable (which is one type of a reversing section) you are using the right parts. There is a wiring diagram at the link below that shows how to do the wiring:
http://1.bp.blogspot.com/-Z5f-7Lpp6I0/UVJgqCWMfVI/AAAAAAAACL0/MV3qlI25eKM/s1600/Dual-Cab-Control-Turn-Table.jpg
Good luck.
