Hello,I have a Marx #333 in need of repair and I have been on Robert Grossman and he has the parts,I am just not sure what to oder as his descriptions dont say whats included,and he will not offer any help as I have emailed him 3 times and called!He emailed me back and just told me to order the parts online,with no help to what I need!You can see from my avatar pic what is missing from the left side of the drive wheels!Here is a list of what I thought i should order…
333/1829 Left Hand Crank Rod and Valve Gear Assembly
Item # 235L
$5.50
Small Size Eyelet Tool, for the most common sizes
Item # 333
$3.50
Side rod links on 333/1829 steam engines
Item # 435
$2.40
Side rod eccentric crank screw for 333/1829 steam engines
Item # 46
$0.15
Crank Spacer
Item # 55
I cannot enlarge the avatar to the point where I have a good view. It looks like the eccentric rod is not connected on either side, while the rod is still connected to the engine body only.by it’s center pin.(?)
I cannot tell much by the size of the image. You could try Olsen’s…
http://www.fauxtoys.com/pages/109-links.html
Yes that is what you are seeing, the crank is broken and the screw and the (is it called the main rod?)is missing,can I email you pics of it ?I have them of both side!Thanx,John
Sure…Ill give it a shot. From the picture the connecting rod and drive rod are still there. Are any rivets missing or are they just malformed ( damaged) ?
Hi,Olsens doesnt have #333 parts that I can see!How do I email you?I sent you a friend request.Thanx for your help!
No,all that is missing from what i know from what you have said is the rod(is it called the main rod?) that connects to the crank,and the broken crank and the the tiny screw that holds the rod to the crank.
FYI
Another parts source
That Train Place - 56644 C R 3 South Elkhart, IN 46516 Phone: 219-293-9182
