Gee Bill, the more I think about it, maybe 27 sheets isn’t all that much. Personally, I’ve lost count, partly because I had bought so many sheets when I lived in my previous home.
I was just getting the layout started, and we decided to move. Being just at the benchwork phase, it was an easy tear down. Then I just recycled EVERYTHING, screws and all.
I have tools and time, but not always money, so I try not to waste any plywood. When it comes to curves I’ve used 3 different methods.
First is use the full sheet and cut out the curve, using the drops for a variety of other elements.
Second is the segment method, using either wider straight pieces, or small curves cut from the previously mentioned drops.
Third is a special method that I used on the helix, where I took sheets of 3/8" BC and 3/8" CD cut them into strips, then into segments, lapping and gluing all the way up. This method would work equally well for a simple curve, but it is more labor intensive.
The first photo is of the next curve to be built on the layout. The piece of plywood 8’ x 3’, and will have to have a couple of small pieces added to the ends to form a 10’ diameter curve. There will actually be 5 tracks with the largest being the 10 footer. No, it’s not the Horseshoe Curve, just 2 mains and 3 yard tracks.
This next photo is an example of the segment style of construction. Some pieces were straights with angled ends, others were curves. One use for scraps is glue blocks for connecting the segments.
Finally the helix and it’s lapped segments. First under construction, second completed, and third close up so you can see the wat the pieces went together.
[img]http://home.comcast.net/~big_boy_4005/helix10.jpg[/im
