I guess I am getting confused with the water issue…
I am not going to say that it doesnt have issues when it gets wet, it does, it starts to expand and eventually it will break apart.
BUT only if there is constant water on the surface. I spilt water on the MDF board on my son’s 1st layout while i was working on it, (juice actually). I quickly dried the surface. It did show signs of expansion, I let it dry and sanded it back down. it never was a problem after that.
For the MDF to break up due to water, the water needs to stay there for a long time.
Another thing i just dont understand, why is water damage an issue anyhow? does anyone have real water in their layout? if so ok, dont use the MDF, but the occasional water spillage such as i had, will do some minor damage, but nothing crutial, you would have to have a lot of water for a long time on the sheet to cause real damage. who does that?
Cripe leave plywood wet long enough and the glue that holds the layers together will let go too. or it will grow mold in the wood. MDF will collect mold too, but it sands off easier than mold on Plywood.
I use MDF around the house for projects here and there, I am not talking about the chip board, MDF is a brown dense board that does create a ton of dust when cut, routed, or sanded.
there are a ton of 1/32 scale slot car tracks made with MDF too, mine will when i get started on it. I have see some routed layouts that have real water features on them too where the car drives through the water and spashes it all over the place. the little river is a plastic tub, but the water does splash all over.
I say if the guy has some MDF layin around and wants to try it. dont bash his idea, just let him know what might happen and let him try his theory out.
Kevin
