Micro Engineering switches
Anyone using Micro Engineering switches? Good? Bad? Quirks?
Some additional wiring needed, but generally very reliable See April 2016 Model Railroader for some tips and tricks. I model in Code 70, and Micro Engineering #6 switches are used almost exclusively.
I have, 16 ME code 70’s #6’s and only one issue as I received a warped one and ME replaced it within a week. I thought very easy to wire the frog but if you use code 70 use the code 83 rail joiners. I highly recommend. The rest of the layout had 2 CVT tunout kits with ME code 70, and CVT ties for mainline and sidings with code 70 ME weathered rail.
Enjoy
TomO
The current products (in HO at least) are DCC-friendly and very good. They deliver smooth operation and require very little tuning. Note that the rails beyond the frog do not have built-in jumpers, so you either have to add your own or power them from the next piece of rail they attach to.
