I purchased four Micro-Engineering Code 70 #6 LH turnouts and two of them have an issue where I cannot throw the points without it going back to original position. They want to stay on one side and not hold on other side when I push points over. Any thoughts on what is causing this and how to fix it? I’d like to try fixing myself as I’d like to get the track laid and everything running sooner over later.
However, when I found this situation on a couple of #5 ladder track turnouts I noted a couple of QC issues. Plastic flashing in the tie areas can interfere witt the points and the throwbar. Take a careful look and if you see flashing take an exacto and use the point to cut away any flashing.
Second, ME uses a soft Nickel silver alloy, bends more easily than say Atlas. I found the turnouts were easily bent especially where the stock rails are cut away to accommodate the points. Careful examination may reveal distortion those points which can affect the throwbar.
I’ve had some that the stock rails and points were not ground smoothly enough to allow the points to close tightly against the stock rails. In an extreme case this might cause the points to spring back instead of locking in the new position.
Be careful when soldering Mico Engineering switches and track. The plastic that they use seems to more heat resistant that most but it puts out some really nasty fumes when it gets hot.
