Micro Plugs ?
Hello,
I wanted to know if anyone knows where I can get the micro plugs similar to what Broadway Limited Imports uses to connect the tender and locomotive together. I am looking for a bulk purchase and would like 8 or 9 pin connectors both maile and female. I ordered a couple from BLI but the price is high along with shipping. I checked Micro Mark and Lichfields Station but they do not have quite what I am looking for.
Any suggestions or help is greatly appreciated. I am looking for quantities of 25, 50 or 100.
Thanks,
Jeff
Mouser.
David B
Hi Jeff, Try Mouser (http://www.mouser.com/) or Digi-Key (http://www.digikey.com/). I’ve dealt with them both and find they both provide fast, excellent service. Regards, Greg
Jeff, how much did BLI want for them? Did this include the wiring harness, etc. or just the plug? I wouldn’t mind having a spare or two on hand. David, Greg, does anyone know the specific part no. from the two catalog suppliers or at least the size/description? Thanks very much.
Exactly! I never used to have grey hair before I tried searching Mouser and other electronics suppliers for less than mainstream components! [banghead]
Guys,
Thanks for the links, I am having trouble finding the plugs that I can use.Does anyone have part numbers or a more specific description for the plugs. I am wanting either 8 or 9 pin single row micro plugs that are black in color preferably.
The one that I purchased from BLI was around 8.00 plus 6.00 for shipping.
Thanks,
Jeff
I would pay the 14 dollars.
David B
Hi Jeff,
I feel your pain. Just out of curiosity I went to a couple of online electronics suppliers, including those mentioned and searched for the sort of plugs you described, to no avail.
I am not aware of your specific application for these plugs so I’ll take a guess and suggest you use a header. They are black and are available in single row configurations. Tony’s sells them as well as any electronics supplier. Tony’s will cut them to you specs so 8 or 9 pin single row is not a problem. Tony’s charges 50 cents per pin.
Connectors at Tony’s
If the header connectors seem like they would work, here is another link to a supplier that carrys them.
Headers at E Goldmine
I wouldn’t pay $14…
I’m trying to find these too.I think they are “JST” format, and I think there are specific “pitch” measurements refering to the distance in milimeters between the pins.
I ordered some from ebay for $6 total for 6 each male and female.They looked correct,but were too large, so I assume I need a smaller pitch.
Interestingly, they shipped direct from China,and were obvously individually hand packed and the package was hand addressed. Must have incredibly cheap labor!
JST 9 pin is common on decoders, but BLI uses 8, 6,and 3 pin.
I have seen the 3 pin at R/C hobby stores for about $4 a M/F set.
I’m alsolooking for the plug they use on the PCM/LokSound boatds, It’s even weirder.
Thank you for the heads up on the Headers, they are close to what I am looking for. I am just wanting an micro connector that will go between tender and loco for decoder hookups. I like the plugs that BLI uses and the Header plug looks to be a good alternative.
Thank you,
Jeff
