mini toggle switches - do they have higher amp rating with lower voltages?
As I have been looking at the specs for mini toggle switches I see that they usually have two ratings for AC voltage and amps:
5 amps @ 250 volts
10 amps @ 125 volts
Will the amps a switch can handle continue to increase if the voltage dropped?
20 amps @ 62.5 volts
40 amps @ 31.25 volts
(You also get these numbers by working with wattage: 5 amps * 250 volts = 1,250 watts. 1,250 watts / 31.25 volts = 40 amps)
Thanks,
Birds
No a set of contacts is rated for amperage not wattage.
There is a limit to how much lowering the voltage will increase the current rating. You can assume that if a higher rating could be gotten below 125 volts, the manufacturer would have claimed it.
In my experience when a third rating is given,usually 28VDC,the current rating for it is the same as 110 volts.
Dale Hz
Thanks for the replies. Makes perfect sense.
Oh and all my toggles are 10 amps @ 125 volts.
Thanks again,
Birds
