Hi all, I just had a few thoughts that I would like to share.
The previous layouts I´ve had, have been in HO scale and mostly on the smallish side and I had tricked myself every time that I needed as many spurs as possible and that on the smallest area possible.
It is an equation that doesn´t really work.especially when you start to barter with yourself regarding the radii you will have, I settled mostly for 18", and that wasn´t always so smart.
The problems all came one after one other. Locos derailing, cars derailing, unable to operate anything longer than a 50´car… and worst of all, a nightmare to operate on as it was so cramped.
I felt the need to start on new layouts as I grew tired on the recent ones…The plans for a “better” layout is always in the works, right?
In the end I got an epiphany when I built a model railroad for the local museum, there it was spacious and I was to make it with lots of landscape and a minimum radius of 30". What a difference!
I scrapped my layout at home and started on a shelf layout instead, no more sharp curves. no turnouts smaller than a # 5 and a trackplan that is possible to expand in the future if I would wish. The space exists as a shelf layout is much more space saving than a roundy.round layout.
Now I can buy all the equipment I like as the layout doesn´t set the boundaries, only the era I´m modeling [:D].
It really makes the hobby (and the layout) much more enjoyable to me, as I don´t have to worry about what I can´t do but instead of what I can do.
So if you are in the position of planning a new layout. Avoid the small radius curves and tight turnouts. Plan for the future and I will promise you that it will provide you with benefits.
Hope it helps someone [;)].
